0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#729185 03/12/2011 2:48 PM
I have 4 different lamps on my bed.
The one I prefer is this one:
http://i185.photobucket.com/albums/x264/uffeg/viking%20in%20Eskilstuna/20110307162.jpg
Anyone who recognize where it comes from.
I need to find 3 more, or four similar to this one.
http://i185.photobucket.com/albums/x264/uffeg/viking%20in%20Eskilstuna/20110307163.jpg
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
those are both appropriate era marker light styles - try http://www.taillightking.com/
squeeze #729243 03/12/2011 6:51 PM
My COE had Arrow armoured clearance lights from the 1950s. The company still exists and I was able to order new lights that were essentially identical, only 12 volt. I have not installed them yet but all I will have to do is change the bulb to 6 volt.
Looking through their catalogue they have similar lights to yours but without the metal strip across the lens.
Try this link and scroll through the pages to see the different lights.
You will have to call them to order. They provide products for truck and bus manufacturers, not the usual consumer but they will talk you through an order.
http://www.arrowsafetydevice.com/marker-clearance?p=1
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Grote, Trucklite, Peterson, K-D, Signal Stat, Superior Signals, and about 15 more all have Amoured Clearance Lamps.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #729763 03/14/2011 8:38 AM
Thanks, now I have some to choose from =)
[email protected]
Also:
I've got a complete set of signal-stat, I won't be using.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Lightholder,
How much were the clearance lights from Arrow?
1954 6100 Chevy Dump, 292 L6, SM465, 2-speed rear
http://community.webshots.com/user/grampsold54
spanky #729815 03/14/2011 3:16 PM
What kind of lamp is it, and how many do you have?
[email protected]
Also:
Grampsold54,
I don't recall the exact cost the of the Arrow lamps but I think they were modest. I am out of town away from my files right now. I will find the invoice, lamp model number and post later.
The lamp is the same, except the lens is plastic instead of glass. Most importantly, they fit in the recesses in the metal bed frame, with the right spacing of bolt holes.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
