1 members (Stovebolt48),
73
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | those are both appropriate era marker light styles - try http://www.taillightking.com/Bill | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | My COE had Arrow armoured clearance lights from the 1950s. The company still exists and I was able to order new lights that were essentially identical, only 12 volt. I have not installed them yet but all I will have to do is change the bulb to 6 volt. Looking through their catalogue they have similar lights to yours but without the metal strip across the lens. Try this link and scroll through the pages to see the different lights. You will have to call them to order. They provide products for truck and bus manufacturers, not the usual consumer but they will talk you through an order. http://www.arrowsafetydevice.com/marker-clearance?p=1
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Grote, Trucklite, Peterson, K-D, Signal Stat, Superior Signals, and about 15 more all have Amoured Clearance Lamps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks, now I have some to choose from =) My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | I've got a complete set of signal-stat, I won't be using. | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | Lightholder, How much were the clearance lights from Arrow? | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I've got a complete set of signal-stat, I won't be using. What kind of lamp is it, and how many do you have? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Grampsold54, I don't recall the exact cost the of the Arrow lamps but I think they were modest. I am out of town away from my files right now. I will find the invoice, lamp model number and post later.
The lamp is the same, except the lens is plastic instead of glass. Most importantly, they fit in the recesses in the metal bed frame, with the right spacing of bolt holes.
Kent | | |
