8 members (Hotrod Lincoln, MickeyP, Peggy M, 55shaker, klhansen, Craig /49 Panel, Shaffer's1950, Otto Skorzeny),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello, My door handles have a little droop. What's the best way to correct this problem? Thank you! | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Tilt you head when looking at them! I haven't found a good way yet. Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | APV60, I just did my driver door last week. First off do NOT be afraid to bend the little tabs back and take it a part. Its a simple job. I found the coil spring that is inside the "cover" and that pushes the latch tongue back when you open the door. It had broken and luckily I had a spare latch. I opened it up, and the spring was good. I used it. The handle now sits up pretty nice BUT if I had it to do again, and I might still do it, I would have went to Ace Hardware, or somewhere else, and got a NEW spring that had loss NONE of its tension as I still have a slight bit of sag.... while you got it a part also look at the square hole the handle goes through. It could possibly be "rounded" out?
When you get it apart, clean/brush/sand the tongue and the "housing" so that it slides back and forth real smooth. Then I put a light coat of grease on it, as well as a drop of 3in1 machine oil at the other moving joints. It works real good now.
Sorry, I did not take a picture of it while I had it apart! But, it is simple. Go for it. | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Thank you. I'll take it apart. | | |
