6 members (Southerntruck, Gdads51, greenie-reddy, HandyAndy, FAST55, Nick in Manitou), 138 guests, and 2 robots.
Topics128,193
Posts1,057,360
Members48,469
Any ideas on how to get my hood open on my 53 GMC truck? The long lever will not release the hood and the other lever does nothing when I pull it.
Pull on the long lever as hard as you can. While doing this, bang on the hood about at the hood ornament with your fist or a rubber mallet.
Y
Y Offline
Have a "helper" push down on the hood while pulling the lever. Sometimes you just have to lift up hard on the hood. You should be able to see if the plunger/bolt is hanging up on the edge of the latch/plate. Push, pull wiggle and giggle it will come open!
Push down hard and at the same time pull the lever as hard as you can, wiggle it if necessary. The mechanism is a very simple release, you push the lever to the side and the cone shaped plunger is released. The slide latch goes around the plunger groove. Make sure you make the correct adjustments and grease the mechanism well before closing the hood again.
Cursing and throwing things always helps. ohwell
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I don't know on a 53 GMC but on a 51 the grill mounts to the frame, not to the surrounding sheet metal like a Chevy. This means if all else fails you can pull the grill and go up from the bottom with a bar or screwdriver to get it released.
Evan
The one on my '54 binds up sometimes. As George said, push down on the hood and pull hard.
slap it open handed on the right or left side to the middle
1949 SUBURBAN
Tell a kid not to open it.
1948 Chevy 1/2-Ton
Got it and thanks for the ideas. Did take another person. Never had this much trouble in the past. Thanks again.
