1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
I'm rebuilding the front end of my '49. I ordered an original ball and socket rebuild kit. I have the tie rod out and have the ends taken apart and cleaned out. The problem I'm having is I can't get the tie rod end ball into the socket. Are there any tips or tricks to reassemble the original style tie rods.
I went with the original style over new style tie rods because I have them flipped under the steering arms and just easier- or so I thought. Thanks for the help,
Jeremy
Riding in the Passing Lane
Put the spring & 1 cup inside with the recess to the opening. . Then put it over the ball. The ball should go in the large opening & slide back. Then put in the other cup in the hole & the screw. Tighten the screw till it bottoms out & back it off a little. Move the joint back & forth to seat it & tighten the nut again & back it off enough to line up the cotter pin hole.
1972 Chevy c10 Cheyenne Super
On my 54 I used the the new style tie rod ends, being that they are not tapered I was able to flipped them to the bottom with no problem.
Ex Hall Monitor
Ex Hall Monitor
I had the same problem when I rebuilt mine ,I ground just a little of the sharp edge off the inside cup were the ball had to go in than I used a C clamp to pop it in.If you look at the old one you'll see the new one comes to a point on both sides where they ground the ball out and the old ones are dressed at the cup where the ball goes in .
Pete
Thanks Tiny- I think I was assembling them wrong with the spring on the wrong side of the ball. I may have it figured it out now.
I guess I never knew you could get un-tapered new style tie rods or I would have bought those instead- may still do that anyway if they're not too pricey.
Thanks for the help guys!
Chato, where did you buy your tie rod ends from for your '54?
DG
Denny G
Sandwich, IL
Any of the vender's sells the straight shank ends, just shop for price since the all come from the same place.
If you do decide to use the originals, chuck the ball in a drill and lap the cups to fit. You will be surprised how much better they will work.
Joe
Ex Hall Monitor
Ex Hall Monitor
For a '38 but might fit. They are a bit pricey.
Denny, Its been a few years since I changed my tie rods but I believe I bought mine from Classic Performance Products but like Joe H stated above I think all the vendors that list the "new style' tie rod ends sell the same one.
Those are a little different than my "new style" ends, but not tapered none the less.
