8 members (Donf, Gdads51, 55shaker, FAST55, Ponchogl, Wickedbass, Cosmo, Hanks custodian),
66
Mod | | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | I'm rebuilding the front end of my '49. I ordered an original ball and socket rebuild kit. I have the tie rod out and have the ends taken apart and cleaned out. The problem I'm having is I can't get the tie rod end ball into the socket. Are there any tips or tricks to reassemble the original style tie rods. I went with the original style over new style tie rods because I have them flipped under the steering arms and just easier- or so I thought. Thanks for the help, Jeremy | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Put the spring & 1 cup inside with the recess to the opening. . Then put it over the ball. The ball should go in the large opening & slide back. Then put in the other cup in the hole & the screw. Tighten the screw till it bottoms out & back it off a little. Move the joint back & forth to seat it & tighten the nut again & back it off enough to line up the cotter pin hole. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | On my 54 I used the the new style tie rod ends, being that they are not tapered I was able to flipped them to the bottom with no problem. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I had the same problem when I rebuilt mine ,I ground just a little of the sharp edge off the inside cup were the ball had to go in than I used a C clamp to pop it in.If you look at the old one you'll see the new one comes to a point on both sides where they ground the ball out and the old ones are dressed at the cup where the ball goes in .
Pete | | | | | Joined: May 2006 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 103 | Thanks Tiny- I think I was assembling them wrong with the spring on the wrong side of the ball. I may have it figured it out now.
I guess I never knew you could get un-tapered new style tie rods or I would have bought those instead- may still do that anyway if they're not too pricey. Thanks for the help guys!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Chato, where did you buy your tie rod ends from for your '54? DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Any of the vender's sells the straight shank ends, just shop for price since the all come from the same place.
If you do decide to use the originals, chuck the ball in a drill and lap the cups to fit. You will be surprised how much better they will work.
Joe | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Denny, Its been a few years since I changed my tie rods but I believe I bought mine from Classic Performance Products but like Joe H stated above I think all the vendors that list the "new style' tie rod ends sell the same one. | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | Those are a little different than my "new style" ends, but not tapered none the less. | | |
