1 members (UtahYork), 128 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
#72341 01/27/2007 7:48 PM
Well I have a 350 in my 64 chevy c-10. Its been leakn alot of oil and i finally replaced the intake manifold gasket. so now i stopped that leak but now its still leakin but looks like in the back. Doesnt look like its leakin at the oil pan..Looks to be on the right side somewhere. Anyone know wat it might be comin from? I am a youngster and man i dont want to have to take it to a shop. I like to accomplish workin on my ride with the help of some stovebolter that got alot more knowledge then me smile
Stovebolt-It is painted
#72342 01/27/2007 8:51 PM
Jed Offline
Bigbambino22:
First 3 places I'd look would be valve covers, oil sending unit, and your fuel pump.
Good Luck with your search.
#72343 01/28/2007 12:29 AM
thank you i will check it out again
#72344 01/28/2007 2:59 AM
Pay close attention to the valve covers, especially if they are the original sheet metal ones. I got some cheap used aluminum covers at a swap meet that permanently fix that oil leak on mine,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#72345 01/28/2007 5:55 AM
Add on to 48bigtrucks....go with rubber valve cover gaskets and put a thin film of Blue Permatex on the CLEAN surface of the head and valve cover. Allow to tack for 10 minutes, then install. This method has never done me wrong. Just be careful not to overtighten the bolts.
