7 members (Otto Skorzeny, UtahYork, Ponchogl, Lonnie, Bicounty, BC59, JW51),
160
Mod | | | Forums66 Topics128,089 Posts1,056,129 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 23 New Guy | | New Guy Joined: Feb 2011 Posts: 23 | Hi everyone names jeff and im from Sydney Australia just bought myself a 1938 Chevy maple leaf 1/2 ton and a 1938 1 ton truck planing to keep most of the original parts but upgrade some also to make it safer as its kind of dilapidated currently trying to find some replacement leaf springs for the front and back but its rather hard to find any parts here next plan is to upgrade the steering and brakes at lest the front and smaller drums at the back as they are giant drums in the back. found some American sites that sell new parts but i might have to get some custom ones made also for things i cant find. well that's a rough outline of my plans so if anyone could point me in the right direction of places that make or sell parts for these beautiful trucks point me in the right direction. and here are some photos http://smg.photobucket.com/albums/v218/jeffism/1938%20chevy%20pickup%20truck/hope the link works and thank you all hope to make some friends and learn some new things. Jeff | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Hey Jeff... Nice to see that a Maple Leaf has migrated all the way to Oz from Canada!  Not sure what your plans are for rear leaf springs but I replaced the worn ones in my '37 with leaf springs from a Chevy S-10 if that helps... much easier to find used that original equipment, so that might solve some of your problem... Hope so! Welcome to the site!  | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Welcome brother 38er.So what's up with the Maple Leaf logo? I also see some body differences like the ribs on the roof.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Welcome to the Bolt!
It sounds like you have 2 trucks? Are you planning to make one out of the two, or fix both of them? Either way, it looks like an ambitious project. Good luck with it, and keep us posted on your progress. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Wow...got your work cut out for you ! Cool to see right hand drive setup, with gas filler on left side. Best of luck with your projects ! | | | | | Joined: Feb 2011 Posts: 23 New Guy | | New Guy Joined: Feb 2011 Posts: 23 | Hey Jeff... Nice to see that a Maple Leaf has migrated all the way to Oz from Canada!  Not sure what your plans are for rear leaf springs but I replaced the worn ones in my '37 with leaf springs from a Chevy S-10 if that helps... much easier to find used that original equipment, so that might solve some of your problem... Hope so! Welcome to the site!  hello 37ChevyTruckGuy thank you for your responce sadly we don't have Chevy S-10's well we have hardly any Chevy's at all. where the a direct fit or did you have to play around with them? also thank you all for you responses its appreciated i have another question dose anyone know what spindles would be a direct bolt on to the original bar axle? or 5 stud drums that would fit the original spindles. thank you all jeff | | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Welcome to Stovebolt! try asking your question in General Truck you will get a lot of guys checking out that forum. Good Luck on your truck. Take lots of pictures as you progress.  | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I don't think there is a drum exchange. I bought a disc brake upgrade from CCP
| | | | | Joined: Feb 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 54 | Welcome to the Bolt. Nice to see our 1938 Numbers growing stronger.
I am just here to learn, and to meet like minded people.
| | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Jeff... When it was decided my rear leafs were too worn and needed to be replaced the mechanic I was dealing with told me to measure them end to end and that a local wrecking yard would be able to match them using S-10 parts... apparently there are several different lengths on different model years but just to be safe I picked up the shackles as well... a shame you don't have many S-10's there but maybe someone else has another suggestion? If you're looking for good info on Maple Leaf Trucks find a bolter called 3B here on the site... He is a wealth of information as he has several old maple leaf trucks and is usually happy to help... his rates are pretty high though... he insists on a "thank you" for any help given...  lol... If you can handle that, get in touch with him and maybe he can offer you some good advice!  | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome helples, I didn't realize Maple Leaf trucks came in half ton versions, thought they were all one ton up to 3 ton. Good score and good luck finding what you need.
Leo | | | | | Joined: Mar 2011 Posts: 7 New Guy | | New Guy Joined: Mar 2011 Posts: 7 | G'day Jeff
Emmanuel Vardos, Canberra ACT Aust.
Just joined and saw your post. Not sure how the forum sit works, I will figure that out later but I did want to say hi.
I also have a recently aquired 1938 Chevy pickup. Mine has a VS commodore back end and an L100 Mitsubushi front end which have be adapted to the 38 Chevy rather easily. This avails modern suspension, modern brakes/running gear to accommodate the 5lt motor I intend to install.
Interested to hear what you e planned for yours
Chevy Chase
The chase is over, the work begins, the dream is alive.
| | | | | Joined: May 2011 Posts: 1 New Guy | | New Guy Joined: May 2011 Posts: 1 | Hello Jeff,
I'm new to Stovebolters and have recently obtained a '38 Chev truck and I'm in Wollongong.
Haven't even posted my profile or pics of the project. Perhaps there might be some useful contact here.
I'm planning on taking the cab of the truck and doing some major changes and will have some parts that I won't be using. This is an unusual item - wide body & long chassis. Some Chev enthusiasts coming to see me next week fora gander
Hoping to get the profile & pics up this weekend.
Cheers - Bunter # 28919
| | | | | Joined: Mar 2011 Posts: 164 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 164 | Hi Jeff Welcome to the bolt, Nice truck, Good luck with the restoration. | | |
