0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
#719510 02/09/2011 3:42 AM
does any know how to remove the top roof to repair inside roof
gregory #719512 02/09/2011 3:48 AM
sawzall? big angle grinder? cutting torch? the inner and outer roof stampings are crimped/spot welded all the way around with the drip rail in the sandwich, you're pretty much stuck with repairing any part of it in place unless you're good enough at body work to cut a section out and replace it .... next choice is replacing the cab with better if it's really messed up
squeeze #719558 02/09/2011 7:20 AM
Drilling out the countless factory spot-welds, around the perimeter of the top, in the drip rail, will seperate the inner & outer roof skins, without damaging either one, beyond repair. Patience & a good spot-weld cutter or 1/4" drill bits, will do the job. Begin by removing the factory seam sill in the drip rail, thus allowing the factory spot-welds, to be exposed. Each spot-weld should be hit with a center punch, to eliminate the bit or cutter from wandering. I prefer a spot-weld cutter, so you have a good backup when reinstalling the top cap. Since both sides of the drip rail are accessible, drilling all the way through both panels, will not be difficult to weld back together, with a good, copper heat-sink, to back up the welds.
I replace the whole roof assembly with a good one on my 63...
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
sounds easier than splitting the roof.
gazim #720113 02/11/2011 7:19 AM
Is sounds easy, until welding a few feet of sheetmetal and top-dressing the welds, suitable for prep, prime & paint. Puddle-welds in the drip rail are much more forgiving, when it comes to the final product. To each, their own. From my personal experience replacing the outer skin of the roof cap, is easier & more forgiving, than an upper half.
I'd recommend drilling the spot welds to remove the top skin, then glue it back on using panel-bond epoxy.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I did mine and it was not bad at all. Well worth the time and energy to get in there and take care of all the crap and rust that is hidden in there.
