5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
1 Offline
Bolters,
What is the part number for the two rear wheel cylinders? Are they the same? Having some issues matching the old ones, so I'm leaning towards them not being OEM.
Richi
What size truck?
What issues are you having?
On 1/2 ton trucks the rear cylinders are the same on both sides (the front cylinders are different on each side).
Riding in the Passing Lane
You didn't say what the issues were but sometimes you have to grind or cut a little off the safety brackets to get the cyls. to fit in between them.
1972 Chevy c10 Cheyenne Super
1 Offline
It's a 1/2 ton with no major mods. Basically both the rear wheel cylinders are different makes. One has the port angled to accept the brake line. The other has the port in the center which connects through a banjo bolt. The Jim Carter wheel cylinder part number ME323/14997 does not accept the banjo bolt, it bottoms out. Looks like I will piece a couple together and make the brake lines fit.
I just did all four of my wheel cylinders, all the lines & hoses were straight shots into the wheel cylinders, rears were both banjo's, both fronts were the same, no left or rights, although mine is a '49 3100.
It sounds like you may have one wheel cylinder for a 55.1 and one wheel cylinder for a 55.2 The 55.2's have the port angled, while the 55.1 is centered and not angled.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
...and those should be available at one of your local parts store. At least one of them should have them. Try Advance Auto. PDQ overnight and no shipping charges.
NAPA picked all four of mine right off the shelf and it was cheaper then having them shipped from LMC.
Larryw
58 gmc 100 with 350 sbc
1 Offline
Ordered some from NAPA, 14497 part number and they seem to fit. Plan to bleed them tomorrow. Reckon the previous owner put a different part on. Thanks
