3 members (dt235sd, 1955 1 Series, 1 invisible),
352
Mod | | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 15 New Guy | | New Guy Joined: Feb 2008 Posts: 15 | Bolters, What is the part number for the two rear wheel cylinders? Are they the same? Having some issues matching the old ones, so I'm leaning towards them not being OEM.
Richi | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What size truck?
What issues are you having?
On 1/2 ton trucks the rear cylinders are the same on both sides (the front cylinders are different on each side).
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You didn't say what the issues were but sometimes you have to grind or cut a little off the safety brackets to get the cyls. to fit in between them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2008 Posts: 15 New Guy | | New Guy Joined: Feb 2008 Posts: 15 | It's a 1/2 ton with no major mods. Basically both the rear wheel cylinders are different makes. One has the port angled to accept the brake line. The other has the port in the center which connects through a banjo bolt. The Jim Carter wheel cylinder part number ME323/14997 does not accept the banjo bolt, it bottoms out. Looks like I will piece a couple together and make the brake lines fit. | | | | | Joined: Nov 2010 Posts: 7 New Guy | | New Guy Joined: Nov 2010 Posts: 7 | I just did all four of my wheel cylinders, all the lines & hoses were straight shots into the wheel cylinders, rears were both banjo's, both fronts were the same, no left or rights, although mine is a '49 3100. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | It sounds like you may have one wheel cylinder for a 55.1 and one wheel cylinder for a 55.2 The 55.2's have the port angled, while the 55.1 is centered and not angled. Samantha | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...and those should be available at one of your local parts store. At least one of them should have them. Try Advance Auto. PDQ overnight and no shipping charges. | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | NAPA picked all four of mine right off the shelf and it was cheaper then having them shipped from LMC. Larryw
58 gmc 100 with 350 sbc
| | | | | Joined: Feb 2008 Posts: 15 New Guy | | New Guy Joined: Feb 2008 Posts: 15 | Ordered some from NAPA, 14497 part number and they seem to fit. Plan to bleed them tomorrow. Reckon the previous owner put a different part on. Thanks | | |
