3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | After a long wait, my 1966 GMC Burb will be in Las Vegas on Saturday morning.
My problem is this. It has a flat sitting on the transport truck and no spare. I have a 2003 GMC half-ton pickup with six bolt pattern.
Will my spare fit the '66 or do I need to find a rim to mount a tire. I don't think I care about back spacing and all, just to move the truck around till I get some new tires on it.
I have looked and am still confused. Did the bolt pattern change when the trucks went metric? If so what year(s) will work on the 1966 Burb?
Thanks for any input. | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | It's the same pattern. 6x5.5. But the centre bore is smaller on the new wheel. So might not fit. Your stock one on the burb has a centre bore of about 3.6 inches. Up to 87 2 wheel and 4x4 wheels will fit.
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | If all you want to do is move the truck and not drive it, why not try a can of fix-a-flat. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The bolt pattern did not change, but the wheel backspacing did, as well as the mentioned hub center bore. The later wheel will not work, as it will rub, possibly hard enough to not allow the truck to move with it on. Fix a flat will no seal a rim or stem leak. Most times, it won't seal a puncture either. Also, most tire shops will not repair a tire that has had fix a flat put in it.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Fist take you an air tank with you. If it was "UP" when loaded then there is a good chance it'll hold air long enough to mooove it. If its tubeless the tire may go back around the rim when you jack it up enough to get air in it.
| | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | Success.
Thanks for your input. I was able to put air in the tire long enough to off-load and get it parked. I just wanted to be ready, as most truckers are not keen on wating around.
Thanks for all the input | | |
