8 members (Hotrod Lincoln, 2-Ton, DadsFirstPickup, Otto Skorzeny, HandyAndy, Peggy M, DES57, Jman), 124 guests, and 2 robots.
Topics128,102
Posts1,056,532
Members48,448
installed tranny in 63 fleetside c-10 inline 6----having problems getting into gears---linkage etc!!!!please help
Did it shift OK with the previous trans?
Also did you check to see if the trans shifted all 4 gears (3 Forward, 1 Reverse) before you installed it?
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
a 4 speed wouldn't have shift linkage, it's a top loader. Must be a 3 speed???
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Did you replace the clutch too?
Larry
I don't own a vehicle that isn't old enough to drink.
Scott,
Seeing it's a C-10 and the mention of "Linkage" it sounds like he has a regular 3-Speed ??
GMC 9500 Fan
Detroit Diesel Fan
Just wanted to be sure we were'nt talking about the clutch linkage,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
could also be typical slop in the selector at the column. Where is your linkage trouble.. Up high, or down low?
