3 members (cmayna, tclederman, 1 invisible),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 5 New Guy | | New Guy Joined: Dec 2008 Posts: 5 | installed tranny in 63 fleetside c-10 inline 6----having problems getting into gears---linkage etc!!!!please help | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Did it shift OK with the previous trans?
Also did you check to see if the trans shifted all 4 gears (3 Forward, 1 Reverse) before you installed it?
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | a 4 speed wouldn't have shift linkage, it's a top loader. Must be a 3 speed??? Scott | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Did you replace the clutch too?
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Scott,
Seeing it's a C-10 and the mention of "Linkage" it sounds like he has a regular 3-Speed ??
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just wanted to be sure we were'nt talking about the clutch linkage, Scott | | | | | Joined: Apr 2008 Posts: 95 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 95 | could also be typical slop in the selector at the column. Where is your linkage trouble.. Up high, or down low? | | |
