3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | good job! I can relate to that - I've got a little forklift, sure handy, and will hate to be without it someday! I don't get so elaborate tho', just have holes in the ends of the extra long forks to peg big U-bolts in and 'hook' things to moose them around  Bill | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Kinda like a fifth wheel hitch, very nice. I have a Kubota mini-excavator thats great for moving stuff around and then some, most versitile machine I've ever had. Does everything.
| | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | I needed to move my 35 1 ton around a lot of times.I put some eye bolts in the front and rear frame holes with some chain and used my tractor bucket to lift and move mine around I wanted to work on the truck more than spend a lot of time building a complacated rig | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | We rebuilt wrecks for many years and still move non runners with a forklift. When you back, you just need to remember that the point of the hitch has to go the opposite way you want the vehicle to go. We even use a forklift to back empty trailers into the shop. We carry an air tank on the forklift to charge the trailer air system. We find that much quicker than waiting for the yard truck to build up air pressure. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used the chain and tractor or forklift method, but there's a pretty good chance of screwing something up. The little axle cradle/swivel thing I made about eliminates that chance. Makes it much more maneuverable and predictable, which is helpful because I've got only an extra foot or so room in the garage where the truck fits.
Grigg | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | Ours works on the same principle, but is a whole lot heavier. In fact it is so heavy, we set it on the ground and stab it with the with the forklift. I think this one should be light enough that one is able to carry it to the forklift. The main thing to have the swivel in the setup so it can turn. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Crenwelge, Can you post a picture of your heavy duty one? Is it something you made or bought? correct, mine is really easy to pickup with one hand and slip on the forks.
Grigg | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I use the red truck on the right, Scott | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | Grigg, ours is something we cobbled together out of truck frames. We have 2 parallel pieces of truck frames with a strap on the end for the forks to slip into. We have a truck frame with the flanges down welded to the 2 parallel pieces. Then we have a piece of truck frame truck frame on top of that of that with the flanges up. That is the cradle to either put under the steering axle or under the drive axle. The swivel is about a 1" bolt with torched holes instead of drilled holes. We use it mostly the front end because there is nothing else to hook onto without screwing up the aluminum bumper. I have always had a lot of pieces of truck frames laying around and we build all sorts of things out of them. Not that they need to be that heavy, but we have the old frames around. On the rear we use a factory thing that clamps on to the 2 forks and has a swivel clevis. We then hook a chain around the back cross member. But we have used the homemade thing on the rear when we couldn't find the factory made lift. I like your idea of having it small enough to slip on the forks. We have too many things laying around that we have to stab with the forks and if we don't hit it just right, we just push it around. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | ..I like your idea of having it small enough to slip on the forks... Sounds like for your shop though you'll need a stouter setup and forklift than I have. Could still be easily portable, but you need forks that are both long enough to keep the mast out of the bumper, and strong enough at the tips to hold the weight you'll be lifting. My forks are just long enough to make it work on an AD bigbolt, and might not be strong enough for a complete truck with engine, haven't tried that yet... It is easy to install/remove and tote, just unhook the chain, remove the T shaped thing with the grab hook that slips behind the forks, lay it on the front part and wrap the chain around it all once, then you've got a nice handle, and I guess it weighs about 20 lb or so. Grigg | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I put a Big Tex grill guard on my pickup and strap a tire on the front and push them around by myself. | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | We use fork lifts for all kinds of things that they really weren't meant for. Here's a picture of us unloading a wrecker I bought a couple of years ago. http://picasaweb.google.com/crenwel...6KG8-e3vEQ&pli=1#5375134413975744466We usually just use two fork lifts and set one end on the ground and then pull the trailer up and set the other end on the ground, but the wrecker seemed a little heavy in back, so we added a loader to the circus. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | |
