| | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 7 New Guy | | New Guy Joined: Jan 2011 Posts: 7 | Hey Big bolters This is my first post and I've been following all of you and your big bolts for the last 6 months. Thanks for the help along the way. I've been struggling with what to do with my brake situation and I took a dive at installing a power brake set up. I purchased a 1/2 ton set up with pedal booster and corvette dual master cylinder. I was suprised that it bolted right up and required minimal cutting it the floor for pedal clearance. I installed a 10# pressure residual valve in both lines and bought adapter lines from Autozone and replaced the rear wheel cylinders, adjusted the brake pads and the system works great. the set up cost about 180.00 (Pedal ,Booster, master cylinder). The only drawback is that the pressure residual valve for the rear takes a second or two to fully releas so there is a bit of drag after you press the brakes. I find it's getting better as i drive. I hope this answers a lot of questions about your brakes. Now I can't vouch for stopping power for a loaded truck , but I can say that I've locked up the tires several times with a light truck. For what it's worth, I like it so far. Good Luck BDF | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...welcome to the Bolt biddaddyfrog. I don't have a big bolt but maybe one day in the future? Got any pics of your truck? | | | | | Joined: Jan 2011 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 68 | i'm glad you had an easier time w/ this than i did. mine was a nightmare. it didnt bolt right up for me. i had to drill new holes for the mounting bracket and move the whole thing back about 10 inches so that i could access my master cylinder from under my seat. maybe it's just my luck, or lack there of.... anyway, glad you are -a- stoppin' now -DVZ | | |
