2 members (Shaffer's1950, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 4 New Guy | | New Guy Joined: Jan 2011 Posts: 4 | I would like to put a 327 in my truck but am not sure if the frame is strong enough to hold it can any body help me and woould also like to get rid of the split rims anybody know what other rims will fit | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Creasy, a 327 wouldn't weigh a lot more than a stovebolt six. The mounts are different, I wouldn't worry about the weight. The split rims are a thing of the past, good idea to get newer ones.
Leo | | | | | Joined: Jan 2011 Posts: 4 New Guy | | New Guy Joined: Jan 2011 Posts: 4 | will 8 bolt wheels off a newer chevy fit or does anybody know thanks
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Go for it Creasy, Not sure if the frame on the front of a 3/4 ton is the same as a 1/2 but lots of guys putting V8's in them. Including me. Some pics of my small block sitting in my half ton are in my photobucket if you'd like to browse.
EDIT: Welcome to the Bolt. There's bolters around your area probably. Keep watch, they're lurking round!!
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There are quite a few folks who have installed a V8. I get the impression that one of the difficulties is that the steering column gets in the way of the exhaust. There should be quite a few posts on the subject.
Also, lots of us have gone to 16x6" wheels on these 8 lug trucks. There are a lot of posts on that too. New trialer OEM style seem to work out OK and now Wheel Vintiques are selling new ones to fit. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Pick up a copy of Street Rodder or Rod & Custom magazine there are numerous vendors that offer mounts, independent suspensions,all kinds of stuff. Realize that 95% of the stuff you look at will be for 1/2-tons so you may have to do some measuring or final fitting of your own. I used 16 x 6 wheels off a 1991 Chev 3/4 ton burb and modified the original caps to fit. I also modified my steering and tie-rod ends for clearance so be aware. http://community.webshots.com/photo/2292616490102454676DiZHOP | | | | | Joined: Feb 2004 Posts: 29,828 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | The frame is plenty strong, and the small block V-8 actually weighs less than the 6-cylinder by a little bit. You'll encounter some interference problems between the steering column and the driver's side exhaust manifold. If the truck has not been converted to 12 volts, that will be necessary, as it's difficult, if not impossible to swap the V-8 starter and ignition system over to 6 volts. There should be some good info on both exhaust systems and 12 volt conversion in the tech tips section. Jerry
| | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I would like to put a 327 in my truck but am not sure if the frame is strong enough to hold it can any body help me and woould also like to get rid of the split rims anybody know what other rims will fit I dropped a 350 into my 1950 3600. The frame is very strong. V8 mounting kits are available. Many modern 8 lug wheels fit, just watch for back spacing issues. Also, to drop in a V8 you will need a power steering box relocation kit, and you will need to reverse the front shock mounts (move left to right and vice-versa). Take a look at my pics and you can see how I handled some of these issues. Good luck and Happy Motoring! | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I think the small block Chevy is a lot lighter than a stovebolt, by around 135 pounds, if I remember right. So you're fine. I've got a 350 in mine and it does very well. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | I used 8 lug trailer wheels on my 51. worked out just fine even with the 72 chevy rear end. I also had no problems with fatter late model tires.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
