2 members (Deegs53, moparguy),
55
Mod | | | Forums66 Topics128,129 Posts1,056,700 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Anybody found a modern gas thank to use on an AD Panel with dual exhaust.
layback
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sounds like you want a gas tank to match whatever dual exhausts you already have?
I have used two different styles of dual exhaust systems with a 235/261 and the stock fuel tank (47-55 panel body trucks).
Patrick's and Chevs of the 40s should have a dual exhaust system for use with a stock tank. Jim Carter used to have a dual-exhaust system that worked (but it did not fit well with a 4-speed transmission).
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | layback, do you have a muffler shop near by?? I recommend letting them custom build one. Put it on the rack and have a conversation with them. I am going to have the same problem and I plan to do what I recommend. A local guy has been doing this for over 30 years and does such a neat job on bending/routing ect. Won't hurt to take a look....and probably save you money. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | I should have mentioned that i have a Camaro front clip and 350-V8 engine. I have the perfect condition exhaust that came off the Camaro, it travel's down and close to each side of the driveshaft. The gas tank is what i don't have.
layback
layback
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I have one for my 3100 from here http://www.rickstanks.com/Its a tank for fuel injection but they have them for everything and custom made also.Or you could build your own also. | | |
