8 members (Leo, wvstovebolt, SuperSport, Flint48, Red75bronco, 78buckshot, TUTS 59, 1 invisible), 85 guests, and 3 robots.
Topics128,129
Posts1,056,697
Members48,454
#713223 01/19/2011 12:02 PM
Anybody found a modern gas thank to use on an AD Panel with dual exhaust.
layback
Sounds like you want a gas tank to match whatever dual exhausts you already have?
I have used two different styles of dual exhaust systems with a 235/261 and the stock fuel tank (47-55 panel body trucks).
Patrick's and Chevs of the 40s should have a dual exhaust system for use with a stock tank. Jim Carter used to have a dual-exhaust system that worked (but it did not fit well with a 4-speed transmission).
layback, do you have a muffler shop near by?? I recommend letting them custom build one. Put it on the rack and have a conversation with them. I am going to have the same problem and I plan to do what I recommend. A local guy has been doing this for over 30 years and does such a neat job on bending/routing ect. Won't hurt to take a look....and probably save you money.
I should have mentioned that i have a Camaro front clip and 350-V8 engine. I have the perfect condition exhaust that came off the Camaro, it travel's down and close to each side of the driveshaft. The gas tank is what i don't have.
layback
Last cry for help.
layback
I have one for my 3100 from here http://www.rickstanks.com/
Its a tank for fuel injection but they have them for everything and custom made also.Or you could build your own also.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
