1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#71330 01/08/2007 4:20 AM
I saw a post in a thread lately talking about heat baffles that are rusted in place, but didn't talk about how to free it up. Well, mine is rusted in place. I can move it about 1/64th of an inch.
Any good ways to get these freed up? Heat won't work, 'cause it is hot quite often anyway. Also, I presume they stick shut. I just got a truck to start after many years sitting and it runs fine, but I imagine this is restricting the power somewhat.
Thanks for all the help
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#71331 01/08/2007 5:43 AM
soak it with diesel or kerosine - OEM suggestion
#71332 01/08/2007 6:01 AM
Spray the hell out of it and tap the end of it lightly with a hammer. Should free up before to long.
My 1953 Chevrolet
1947.1 Gallery
#71333 01/08/2007 8:13 PM
Spray it with a good rust buster and tap it right to left and so on it will come loose. DO NOT TRY TO TURN IT TO BREAK IT LOOSE. Also don't tap on the counter weight as it will break off if you use to much pressure.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#71334 01/08/2007 8:23 PM
It's on the vehicle so about all I have is turning and counterweight tapping right? Carefully I guess.
1947 Chevy COE
#71335 01/08/2007 8:50 PM
Ex Hall Monitor
Ex Hall Monitor
It's not that difficult to remove. All you need is a new gasket when you're ready to go back on with it.
#71336 01/08/2007 9:28 PM
What I did was keep soaking it with a rust buster (I used PB Blaster) and tapped it from both ends. The shaft moved back and forth, then I rotated the counter weight when it was free.
This worked for me. Best of luck
Dennis
#71337 01/08/2007 11:59 PM
Would be easier if it weren't Cabover frown
1947 Chevy COE
#71338 01/09/2007 1:25 AM
Itd be easier if you had smaller hands. grin Have your wife lend a hand. Usually its my square head that gets in the way more then the truck! :rolleyes:
My 1953 Chevrolet
1947.1 Gallery
#71339 01/09/2007 4:20 AM
Ya, put her to work. Maybe that is what she can do between 8 and 10 tomorrow am, in leiu of sleeping grin
1947 Chevy COE
#71340 01/19/2007 8:30 AM
One more question about this. Does anybody have a picture, or description of the balance weight position when the baffle is open?
1947 Chevy COE
#71341 01/19/2007 3:55 PM
Ex Hall Monitor
Ex Hall Monitor
Check your e-mail. It shows my 38 in the open position.
