| | | Forums66 Topics128,007 Posts1,055,279 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | I recently replaced a bad muffler on my 53 (1960 235) with an 18" glasspack. Has anyone experienced any flow issues with these? Mine sounds horrible at idle, almost like its missing..just a rough idle. No obvious leaks in the pipe, I welded everything, and the engine sounds smooth when your standing over it. I even went as far as to replace the plugs and wires, swaped out the carb. same issue. plenty of fuel to the carb too.
Chris
1953 Chevrolet 3100
| | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | Most likely it was tuned with a bad muffler, now that it has free flow you might mess with the idle adjustment a little. In is lean, out is rich, go 1/2 turn each way and see what it sounds like. Idle screw will not fix anything above a idle, if its not running right out on road, then you have other problems.
Joe | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | Seems to be the sound waves are different that are created by the 6 compared to a v8 that is normally used with a glasspack. Read about this in the info for my Langdon's headers on my 250. Sorry I Lost the info of course.
