Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (cmayna, jay d, 2-Ton, 2 invisible), 44 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#712459 01/17/2011 12:18 AM
I recently replaced a bad muffler on my 53 (1960 235) with an 18" glasspack. Has anyone experienced any flow issues with these? Mine sounds horrible at idle, almost like its missing..just a rough idle. No obvious leaks in the pipe, I welded everything, and the engine sounds smooth when your standing over it. I even went as far as to replace the plugs and wires, swaped out the carb. same issue.
plenty of fuel to the carb too.
Chris
1953 Chevrolet 3100
Most likely it was tuned with a bad muffler, now that it has free flow you might mess with the idle adjustment a little. In is lean, out is rich, go 1/2 turn each way and see what it sounds like. Idle screw will not fix anything above a idle, if its not running right out on road, then you have other problems.
Joe
Seems to be the sound waves are different that are created by the 6 compared to a v8 that is normally used with a glasspack.
Read about this in the info for my Langdon's headers on my 250. Sorry I Lost the info of course.
