7 members (Wrenchman, Oswald, Chris's 46 / 515, 55shaker, carbking, WICruiser, 1 invisible),
52
Mod | | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | Hey Everyone, i came across this picture today, http://rides.webshots.com/photo/1484085114080251109nyGsXpi belive it belongs to Grigg3? Anyways, i was wondering, was this bed made for my truck, the 6400 2 ton? Just curious because i have not seen one around before. All i see with these trucks are the flatbeds and grain beds.Just tryin to find one.Thanks Dan | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | That looks like a 3800 series 1 ton to me. check out the links below, to the '50 model 1 ton I had. That's a 9 ft. 1 ton bed, in the photo you posted. There was never a '47-'54 1 1/2, or 2 ton pickup. However, there was a 1 1/2 ton pickup available through 1946. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, that's my 1 ton with a 9' bed.
Grigg | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | does the 1946 long bed work for my 6400? you say its a 9 ft bed, im gunna go measure my naked frame rails now.
Danny | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 6400 is about a 161" wheel base. 6100 and 1 ton pickups and cab/chassis used a 137" wheelbase.
No, you can't simply put a 1 ton bed on a 6400 truck, considerations are the extra 2 feet between cab and bed, fenders not fitting over the wheel or wheels, inside wheel may hit bed sides and running boards not lining up with the front fenders.
Grigg | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Grigg, I think he may be asking if one of the Art Deco 1 1/2 ton pickup beds will work on his 6400. Those 1 1/2 ton pickups are so "RARE" it'd be a shame, (if you ever found one) to part it out, for just the bed swap. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | Where can i find measurements of a 1 ton bed for a 6100? i want to lengthen one and do some custom work to make the running boards and fenders fit in as well as making the bed sit behind my 6400 cab nicely. it can be done.is wheelbase basically the width from wheel to wheel? | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | dantheman49-6400 Look at my photobucket pictures .I put a 8 foot bed on my 1953 4400 still working on the fenders . | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Wheelbase is from center of rear wheel to center of front wheel. Dimensions can be found in the Salesman's data book among other places. Try here http://chevy.oldcarmanualproject.com/Grigg | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Check Johnnyc47's thread for info on the pickup he is building. | | |
