| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | Hello, How can you tell if the engine is a 292 or a 250? I just bought a 1968 6cyl.engine out of a 1 ton truck the block number are 3921988 If anyone can help me out with info? Thanks, Jerry in Tennessee | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | A 292 will have taller Side Covers, approx 6 inches tall. Also the Motor Mounts will be staggerd instead of even across. On a pad by the distributor, you will find the Engine Code. Post the code and we can tell you more about the engine.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The casting number posted doesn't come up on Inliners. Closest one is 3921968 (easy mistake to make) which could be either a 230 or a 250 from '64-'76 used in Chevrolet or Oldsmobile applications. The serial number from behind the distributor will be a better indicator of what it is and where it came from originally, as there is a possability it wasn't original to the truck it came from.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | Check fuel pump location, 230,250 is in the front, 292 is in the middle of the engine.
292;s will have a heavy duty looking water pump with extra hoses and a bigger harmaonic dampner (3 or 4 pulley grooves).
Joe | | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | 250 or 230? The numbers I got behind the dis. were F0430TF or maybe T0430TF was is the difference between these engines? are parts interchangeable? The motor I have came out of a 1968 one ton flatbed I was thinking it may be a 292 but the fuel pump is closer to the front. If anyone can help me with the I.D. I will say thank you in advance, Jerry in New Tazewell, TN | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | no need for numbers on this one. just look at the lifter gallery covers or fuel pump/motor mount location on pass side. if the covers are 6" it's a 292 if the are 4" it's a 250. if the motor mounts are straight across from each other it's a 250 if the pass side one is foward a bit, it's 292. i have had people argue casting numbers before when i bought a engine, i don't even try any more. as long as you know what you got it's fine.soon you will be able to spot them from a mile away. now a 230 and a 250, different story! | | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | whats the difference between the 250 & 230? | | | | | Joined: Sep 2010 Posts: 13 New Guy | | New Guy Joined: Sep 2010 Posts: 13 | Please tell me more on the 230 vs 250 story this is 1968 chevy one ton flatbed engine. thanks, jerry | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i doubt it's a 230 they stopped making them in '64, i think. they had 20 less cubic inched, i think they had a flat or at least less resessed piston. so which is it 250 or 292??? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The TF code is for a 250 with the 4 speed and HD clutch. The first part of the code is the plant source, usually F is Flint Michigan and T is Tonawanda New York. No real differences in the engines other wise. The next part is day/month the engine was built.
