0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#708993 01/05/2011 3:05 AM
Hello, How can you tell if the engine is a 292 or a 250? I just bought a 1968 6cyl.engine out of a 1 ton truck the block number are 3921988 If anyone can help me out with info? Thanks, Jerry in Tennessee
A 292 will have taller Side Covers, approx 6 inches tall. Also the Motor Mounts will be staggerd instead of even across. On a pad by the distributor, you will find the Engine Code. Post the code and we can tell you more about the engine.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
The casting number posted doesn't come up on Inliners. Closest one is 3921968 (easy mistake to make) which could be either a 230 or a 250 from '64-'76 used in Chevrolet or Oldsmobile applications. The serial number from behind the distributor will be a better indicator of what it is and where it came from originally, as there is a possability it wasn't original to the truck it came from.
Bill Burmeister
Check fuel pump location, 230,250 is in the front, 292 is in the middle of the engine.
292;s will have a heavy duty looking water pump with extra hoses and a bigger harmaonic dampner (3 or 4 pulley grooves).
Joe
Joe H #709577 01/07/2011 1:14 AM
250 or 230? The numbers I got behind the dis. were F0430TF or maybe T0430TF was is the difference between these engines? are parts interchangeable? The motor I have came out of a 1968 one ton flatbed I was thinking it may be a 292 but the fuel pump is closer to the front. If anyone can help me with the I.D. I will say thank you in advance, Jerry in New Tazewell, TN
no need for numbers on this one. just look at the lifter gallery covers or fuel pump/motor mount location on pass side. if the covers are 6" it's a 292 if the are 4" it's a 250. if the motor mounts are straight across from each other it's a 250 if the pass side one is foward a bit, it's 292. i have had people argue casting numbers before when i bought a engine, i don't even try any more. as long as you know what you got it's fine.soon you will be able to spot them from a mile away. now a 230 and a 250, different story!
whats the difference between the 250 & 230?
Please tell me more on the 230 vs 250 story this is 1968 chevy one ton flatbed engine. thanks, jerry
i doubt it's a 230 they stopped making them in '64, i think. they had 20 less cubic inched, i think they had a flat or at least less resessed piston. so which is it 250 or 292???
The TF code is for a 250 with the 4 speed and HD clutch. The first part of the code is the plant source, usually F is Flint Michigan and T is Tonawanda New York. No real differences in the engines other wise. The next part is day/month the engine was built.
Bill Burmeister
