1 members (NJC),
77
Mod | | | Forums66 Topics128,283 Posts1,058,506 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I hope to get some garage time later today,to fit my new mirrors, an early Christmas present from Mrs Jock. Just depends when I get home from work,it's snowing..... Jock, as my old granddad use to say, "you're the cat's pajamas." Probably doesn't translate...
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Big, thanks for the compliment. Well, I got one mirror installed. Looks good if I say so myself.(pics to follow) Got the holes drilled for the second one and got beat by the cold. My fingers were totally numb! Due to the positioning i've gone for on the doors themselves,it's a really tight squeeze to get the nuts on. I'll need to procure the services of Mrs Jock(tiny hands) or befriend a Gynecologist!  Edit: Got the mirrors on and some pics to prove it. Here.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | This weekend I was intent on clearing a path to my truck. There was a 3 shelf unit in front of it in the garage. The entire contents of that shelving unit AND the unit itself have been relocated! The first step in a hopefully not too long journey has been taken. Now I just need to find out where the heck I was on it three years ago! Wish me luck.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Neil, when you find the truck take some pics.
~Jim
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Got all the new whitewall tires and black powder coated rims on today. New cool lowered stance | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Got the A/C condenser and trans cooler mounted in front of the radiator. Was ready to start mounting the electric fan in front of all of it, . . . . now where'd that thing go . . . hmmmm . . apparently got thrown out with the load of empty boxes left for the garbage men - I forgot to bring it in the night before - son of a monkey.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Ordered the left side Cab Windlace Channel Guides. Thought I had ordered both sides at one time but it seems they don't come in pairs.
~Jim
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Got the FireBolt decorated for tonights Santa Claus Parade....  | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | BIG CHEVY 3600 - You betcha'. I need to update it in the gallery, too. Great idea.
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Well, yesterday I got the rear valance and rear bumper put on the panel. Two less pieces to worry about!! | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Big step today, Got the new engine and transmission [350/350] bolted in the 38. Now Ill get to work on the power steering upgrade.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | I had a dead battery this week... kinda odd. 12.0x volts. However, it wouldn't throw over in the cold.
I put the battery charger on it and went to bed.
I checked the cells in the battery and only one cell was slightly low on water, so I topped it off with a few ounces of water.
I checked it not running at 13.4 volts after the re-charge... fired right up with no problems. I checked it running and it was running at 14.5 volts.
I was having a weird thing with my brake lights staying on... turned out the ol' stop light switch had worked itself loose, so I'm guessing it was draining the battery down enough to be a pain.
I checked and cleaned the connections on the batt. terminal to be on the safe side... snugged up the stop light switch... and put it all back together.
vroooooom.
I'm hoping that is all that it was.
-W
| | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | Got the bedwood cut and routed, ready to be stained and urethaned.
Got the plan of attack figured out for the power door locks and power windows as well.
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Working on rebuilding the brakes on my '53. Got the e-brake cables installed last night, now waiting for the correct shoes to arrive from Classic Parts so I can button up the rear brakes. Next step...rebuild the MC.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Finally hooked up my new EZ wiring loom, NO SMOKE!  It's so much easier to start now instead of bridging the starter. No front lights though, I'll need to investigate further. Suspect...cheap re-pop light switch..... The new LED tail lights and bedroll turn signals are really bright! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Got the bedwood cut and routed, ready to be stained and urethaned.quote] [quote=The Green Farmer]Got the bedwood cut and routed, ready to be stained and urethaned. I might be hitting you up for some dimensions!  Jerry | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | My 261 block has been cleaned and checked. The 235 head was cleaned and checked. Results: The head, cracked in 4 places... a "no go". The block can't be honed to clean up as hoped. It's already at .060" oversize. Found and snagged a new set of 261 Sealed Power pistons (.080" over) on Ebay for $120. I was told "good luck on finding .080" oversize rings". I called Hastings and they could set me up for $133 but the guy I bought the pistons from is shipping a set of Hastings for $67! Combined shipping with the pistons. I get all up and excited about saving money. I could certainly use it on bearings and gaskets! I called the machine shop and gave them the "go-ahead" to bore the block .080" over. Next week I'll swing the process for a 261 head from a buddy! I'm excited as all get out! Can ya tell? Jerry  | | | | | Joined: May 2001 Posts: 1,908 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,908 | The last thing I did with my '48 is park it along side the house. The city of Missoula has been using real salt (sodium chloride) the past 2 years on icy roads. I'll drive my '48 on the liquid deicer (with lots of rinsing) but I won't drive it on NaCl.
I'm really bummed.
- 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I noticed an automatic tranny leak at the fill tube..and it even has a new o-ring and gasket. :mad: I started to check into it but thought batter of it and went in the house where it was nice and warm  | | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | I replaced the blower fan on my heater today and replaced my rusted out fuel tank tank with a good used one as well. The used tank also had a good sending unit. Now my fuel gauge works! Next on my list is the windshield wiper motor... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I noticed an automatic tranny leak at the fill tube..and it even has a new o-ring and gasket. :mad: I started to check into it but thought better of it and went in the house where it was nice and warm  Funny how even a tiny amount of ATF has the ability to look like a major oil spill! Mine leaks too Alvin,i'll change out the seals when I re-do my trans fluid/gasket and filter. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Put some new, bright shinny bumpers on today. A Christmas gift from my better half. Switched to a 54 bumper so we can move the license plate.
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | reasembled my new leaf springs ive had in a shed since 1996. took em apart and had powdercoated. reasembled the front springs today with the poly liner between each spring and stainless bolts and new center pins. look awesome. tomorrow im going to reasemble the rear leaf springs back together. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Un-wrapped my new front bumper. Nice! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Un-wrapped my new front bumper. Nice! Sounds much more fun than getting under the truck and sorting leaks,and anyway it's not a leak,it's just marking it's territory!  The shiny chrome will distract you from the puddle forming underneath!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | Haven't driven mine for a month.So I went out today fired it up and washed the windows. Gonna take it to Home Depot tomorrow to pick up a new toilet.  | | | | | Joined: Dec 2010 Posts: 34 New Guy | | New Guy Joined: Dec 2010 Posts: 34 | I just recently got my truck. (1946 1.5 ton) It's been sitting for 30+ years so I've been removing all the junk from the previous owner that had accumulated in the cab and on the bed. Since the wooden bed had rotted and collapsed, I took pictures and measurements of what was left so I can make the new one as close to original as possible.
I also jacked up the front and rear to loosen up the slightly frozen brakes. The steering was seizing up as well. I'm just about ready to load it on a rollback and bring it home and start the restoration.
46 Chevy 1 1/2 ton
| | | | | Joined: Dec 2010 Posts: 44 New Guy | | New Guy Joined: Dec 2010 Posts: 44 | Finally found a replacement coolant temperature switch. Should be delivered to the local parts house tomorrow... | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Finally got it starting from the ignition key, so much better than hotwiring it. Ironed out a couple of ground problems,due to thick powder coat.
Ran the engine and found a water leak,thankfully just a pinched gasket at the thermostat! It's been in the low teens here recently and I was worried I hadn't used enough anti-freeze,I was fearing the worst!!
Relieved and supping a cold one as I type..... 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | I got a new set of gears coming for the 37,2.79s were a little too much so I got some 3.70s on the way. The 235 never acted right with the highway gears and I miss winding it up around town to hear the mufflers so with the 3.70s I should get that back and with the 5 speed still be able to cruise at 65 on the highway,as soon as the parts arrive they will be going in. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The last thing I did with my '48 is park it along side the house. The city of Missoula has been using real salt (sodium chloride) the past 2 years on icy roads. I'll drive my '48 on the liquid deicer (with lots of rinsing) but I won't drive it on NaCl. I'm really bummed. Dang, I thought it was the "last best place". -
~Jim
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | hey Wally, don't be too quick trusting the liquid, which is calcium chloride brine - a very hygroscopic material, meaning it attracts and binds water and gets in every nook and cranny .... I can tell you from experience it's nearly impossible to rinse off well and waaaay worse than the salt/grit mix for causing corrosion  Bill | | | | | Joined: Oct 2010 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 22 | Removed Front fenders, inner-fenders, grill, front bumper, valance, radiator, and bumper brackets, knuckle skin, and wiring. Tore down a spare front wheel assemblies in prep. for disc brake kit. It was just such a beautiful day it would have been a shame to waste it. | | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | A few days back I was back home in Greece where I am restoring my 48 Fleetmaster witch is converted to a truck. The rear sheet metal of the cub was in a very bad shape so a new plate was made and welded in place: I also started dismantling the motor for inspection http://s875.photobucket.com/albums/ab317/Jianis/Chevy48%20Fleetmaster%20truck/Jianis | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What a neat truck, Jianis. | | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | Thank you Cletis.
Normaly I should never start with it but its the only surviving 40s truck in the island of Crete that can obdain a licence to drive on publick roads.It just need some....work.
Jianis | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | i did go out to the garage and admire her though I have no time to work with her today.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | WooHoo! Took first test ride today since rebuild! Open drive axle, T5 trans, new wheels and tires, S10 gas tank, original 216 engine, model A taillights! | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | It looks like its going to be next week before the 37 gets the new gears,got 9 inch parts instead of 8 inch so the guy is building me another third member and I have to send this one back. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | HAHA, I got pulled over tonight in my bolt! I was crossing over the double yellow.....because.....I did not want the water that puddled on the road to get the truck wet.
The officer did not even say 'nice truck." 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
