| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Merry Christmas everyone! Just wondering what to do about the shift indicator light or lever whatever you have. How did you mount it and what kind do you have for your A/T ? Thanx, Mike | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | depends on the year you've got Mike, using a floor shift is common, and with some you can cut the column tube and replace it with one from a 67-72 that had an auto trans so you get the shifter and indicator on the column
Bill | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Well I guess it would depend on what type of column i'm using.lol
I'm installing the original 4 sp 1948 column w/ a 350turbo and a floor mounted Gennie shifter.Gennie makes one but they cost as much as the whole shifter new. Just c-ning if there is another way other than the shifter knob.(or by feel) | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | check the wreckers, the pattern of the 350 is common and you should be able to find an OEM floor shift cover with the markings
Bill | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | | | |
