1 members (Snowman51), 94 guests, and 12 robots.
Topics128,014
Posts1,055,324
Members48,419
#706149 12/24/2010 9:35 PM
Merry Christmas everyone!
Just wondering what to do about the shift indicator light or lever whatever you have. How did you mount it and what kind do you have for your A/T ?
Thanx,
Mike
depends on the year you've got Mike, using a floor shift is common, and with some you can cut the column tube and replace it with one from a 67-72 that had an auto trans so you get the shifter and indicator on the column
squeeze #706162 12/24/2010 10:11 PM
Well I guess it would depend on what type of column i'm using.lol
I'm installing the original 4 sp 1948 column w/ a 350turbo and a floor mounted Gennie shifter.Gennie makes one but they cost as much as the whole shifter new. Just c-ning if there is another way other than the shifter knob.(or by feel)
bowtiesr4me #706167 12/24/2010 10:28 PM
check the wreckers, the pattern of the 350 is common and you should be able to find an OEM floor shift cover with the markings
squeeze #706181 12/25/2010 12:16 AM
Thanx Bill
