7 members (1955 1 Series, Dave1234, UtahYork, Bill Hanlon, Steelonsteel, 2 invisible), 53 guests, and 1 robot.
Topics128,208
Posts1,057,446
Members48,471
I have my grandfathers 51 gmc which was a one owner and has lots of memories as my grandfather and I spend a lot of time in that old truck. It was a 3/4 ton work truck and I am planning on restoring back to when I was a kid. It has a huge checker plate steel rear bumper with a big trailer ball mounted on the steel plate and had fender bliners and I want to make it as original as possible but more interested in taking it back to when I was a kid working on the 40 acres with my grandfather. So I will try to keep it 6v positive ground etc. Will that be a real probllem to keep it 6v positive ground?
I have just retired so I look forward to this project.
thanks
chamer
Nice project which I'm sure will be very rewarding. This is a good site for information and help.
Some may argue about the 6V vs 12V but I think 6volt is just fine.
Post that question over in the Electrical Forum and you'll find what others think...... do a search and find hours or reading!!
Good luck. Keep us posted and what we can do to help.
Congratulations on your retirement. Nothing like it smile
Grandad's happy you're restoring memories. The rest of us need pictures smile
Brian
Slinger, WI
'37 3/4 ton (grandpa)
'11 3/4 ton (grandson)
http://picasaweb.google.com/lh/photo/4xMv20nIhYF_AUPgEkRiFQ?feat=directlink
Smokey 56
Smokey 56
Welcome!
Dan and Melina from MN. 1956 Chevy/GMC custom 1 Ton dually step side short box.
One of the main things with a 6 volt system is to make sure your battery cables are heavy enough. The ones you buy in Walmart won't cut it for a 6 volt system. I believe it's O gauge or heavier that you need. The people in the electrical forum can confirm that.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
