1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | what would be a comfortable speed on the hi way if a 46 chevy 2 ton flatbed? with orig 216 6cly | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Assuming stock configuration;45-50 mph on level ground. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i have a rebuilt 1960 235 and the sm420 trans 2 speed rear in my 46 2 ton. she will do 50 but it cruises at about 40. philip | | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | thats fast enough at 40mph for me in this ol gal... thanks will get a slow moving vehicle triangle and stick to the slow lane and be grinnin like the town idiot  | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | In my truck 40-45 is plenty. Brakes, tire condition all come into play. Also without a load these big bolts are a bit light and bouncy in the rear. Take it out and drive it, get used to it. After that then look at the speedometer and see what it says. Have fun. Don | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | my 51-6100 at 53 with a fresh 59-235 is running 2700 rpm according to the tah i had on it. 45 is where it sounds the best but on the highway i run it at 50. | | | | | Joined: Sep 2010 Posts: 33 New Guy | | New Guy Joined: Sep 2010 Posts: 33 | In my '52 2-ton with a 235 40 mph feels best. Forty-five is doable, but seems like I'm pushing it. At 50 it feels like it's coming unglued. | | | | | Joined: Feb 2010 Posts: 478 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 478 | My 46 COE has a top speed of about 40, when your seting on top of the front axle things are a little more bouncy. Even with new front tires | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | If we drive enough of these trucks, maybe they will bring back the 55 limit and we won't seem so slow. Remember those days....? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Highway ! Not in mine I stay on the access roads .40 to 45 is comfortable but will run 50 topped out. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My '54 GMC 2 ton is without title right now so I'm not driving it,but as it's currently set up,my number cruncher indicates it'll cruise at about 80,with a full out redlined top end of 102,if the 302 can work up enough power. (It's a little ways from stock though.302 six,5 speed OD,3 speed OD,2 speed axle w/6.40 high) Speed
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Speed, Thanks for the laugh, as I thought about the look on my face if I were doing 102 mph in my '41 fire truck. I REALLY like the phrase "feels like it's coming unglued . . ." That Star Trek "shooting into warp speed" effect surrounding the truck, parts flying off in all directions, my cheeks being drawn back in the g-force effect, and sheer terror written all over my face, as the scream I'm uttering is lost to the sound barrier. -Michael | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | Does anybody have any experience with the Advanced Adapter Ranger Torque Splitter Overdrive as a way to help with High Way Speed? As I understand you can get it with 27% overdrive. Between my two speed rear (currently unknown ratios, but stump pulling low for sure) and my sm465 thought it might help the truck work easier at "highway speeds" whatever they happen to be. Thanks. | | |
