0 members (), 171 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#70167 12/17/2006 12:00 AM
Yet another post on the beaten to death subject of the 67-72 4.10 pumpkin swap into an AD...bear with me.
At the junkyard today I ran across a '69 or so
1 ton C-30 chassis and cab with Open Road frame mounted camper body. Looked like a cool rig in it's day, by the way. It is a factory automatic truck. What are the chances of this having 4.10s?
The tag on the inside of the glove box was painted over, so I couldn't get any info from that. It didn't have rear wheels on it and was sitting on the axle. I couldn't turn the axle to try and count pinion/axle revolutions or pull the cover very easily to count ring gear teeth. Plus the yard was closing and I had to leave.
Maybe somebody out there would know if there's a good chance on finding 4.10s in this thing because it's an automatic? If so, I'll probably go back and pull it out.
Steve
'49 3800
'52 3600
'57 3100
The story that I have been told is that it has to be a 3/4 Ton wwith an automatic.
1951 1 Ton Completed
My book says a C30 could come with a 6.17, 5.14, 4.57 or a 4.10 rear, but doesn't specific which trans. comes with which ratio. There's also no guarantee that the rear hasn't been changed or special ordered, I would check the ratio myself if at all possible,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
