4 members (Steelonsteel, bajabob, Hotrod Lincoln, 1 invisible), 172 guests, and 3 robots.
Topics128,261
Posts1,058,327
Members48,485
#701011 12/05/2010 7:04 AM
I had the oil changed in my 72 today. I was planning to go with Valvoline Synthetic, but the manager told me it was "too old for sythetic." I didn't push the issue as I have no issue with conventional Valvoline but afterward I got to wondering if I'm missing something. I understood that the sythentics were fine for older engines.
Any thoughts?
Willie
'72 Highlander
Swamp Angel Truckers
Yep, no reason synthetic isn't gonna help reduce wear in an older engine as well as a new one. Now if your '72 is gulping oil then you would be better off staying with the cheaper oil.
Just how old was that "manager"?
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Based on all the reading I did on the subject before I made the switch to Mobil 1 synthetic about 7 years ago you should break a new or rebuilt engine in using conventional motor oil and then switch to synthetic after break in.
I am running synthetic in my 350 cu in. Gen 1 non roller cam Chevy V-8's, I have 3, and in my 1985 5.0 HO roller cam Ford.
No problems to report.
Denny Graham
Sandwich, IL
The "manager" was a young guy to me, but not a wet-behind-the-ears kid. Everything else we talked about made perfect sense to me.
Willie
'72 Highlander
I had my engine completely redone in 2006 and the mechanic that did the work said to use regular oil until i got some miles on it. i waited until i had 5000 miles then changed to synthetic at his advice before my trip to KC.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I have a 1956 235 straight 6 in my 1949 chevy truck and I was told to only run nondetergent 30 weight and clean with kerosene every couple of oil changes. I would like to run synthetic but was told the old motors don't like it.
What do you think about the Z-ALT additive? Snake oil or is it good for my motor?
Someone gave you some very incorrect information. Detergent oil and synthetics will be just fine in your engine. Leave the nondetergent for the air compressor or lawn mower. As far as the additive, snake oil. Just use a known quality motor oil, I use Valvoline myself, and you'll be fine. Most of the cam/lifter problems come from poor break in procedures, incorrect assembly, or improperly matched/poor quality parts.
Bill Burmeister
I run Mobil 1 15W50 in everything from lawnmowers to old tractors. I like the fact that synthetic oil can stand extended drain periods.
>>clean with kerosene every couple of oil changes<<
What did they want you to clean, the paint off of it?
If you want the inside of the engine to stay clean, hook up a good PCV system and change the oil on a regular basis.
I use 30w nondetergent in the compressor, but 5-30 or 10-30 in the mower. My 292 gets Mobil 1, 5-30 on a six year old build.
'67 GMC 3/4 292 4spd
I'm with Richard except for the 30w in the air compressor. It gets cold here and 10w suits it better. I have even been know to put used (but clean Mobil 1) oil in the mower. I can hear the outcry now! :>)
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Not too old. You are perfectly fine using a full synthetic oil except, as mentioned, for breaking in a rebuilt engine. High ZDDP synthetics are available for older and high performance engines.
Quote
As Bill mentioned...snake oil. Modern oils, especially synthetics, are precisely engineered with an additive package to handle specific applications. Supplementing with off the shelf additives adds unknown chemicals and can actually cause problems...particularly the ones that contain chlorine.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
