| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well, my re-wire job is almost completed. The last hold up is the tail lights. I am using LED's on the rear with little leds in the box rails. EVERYTHING worked prior to my rewire job. The led taillights work ok but the little lights work on Brake and Stop but will not light on Parking lights. They just glow a little. I know this should be sign of a bad ground but the same light works ok on stop and turn. What am I missing here?I have changed bulbs to no avail and checked the power going to the bulb,OK | | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | First of all, you say brake and stop - I'm guessing you meant brake and turn?
Brake and turn are both same brightness so not surprising those work. Just guessing here - I think the LED's need to be designed for the 2 different levels of light. I suspect the LED tails have 2 sets of LED's - 1 for parking, that remains on, the other for brake and turn. I know the taillights are designed to work for both stop/turn, your "little lights" may not be. Don't know how you've wired them so not sure what might be happening. Something to look into until someone more knowledgeable chimes in.
I'm watching this because I get mine back from the painter in a few days and begin to rewire, and I'm using LED's all around.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you are referring to the "brake/turn"lamp and the lamp is an LED. Maybe the LED's do not draw enough current to allow a traditional flasher-tube to work properly. Some vendors offer solutions for this problem (this reality?) in the way of resistors and/or an updated flasher (for 12v lamps, I do not know if a 6v LED bulb flasher is available for use with 6v LED lamps). On my 6v positive-ground COE, I plan to place a 6v-12v converter under the dash and use 12v LED bulbs and a 12v LED flasher. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I mentioned that they all worked properly before I started the wire job/ I have regular bulbs in the front.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Oct 2010 Posts: 24 New Guy | | New Guy Joined: Oct 2010 Posts: 24 | Usually leds have a pretty narrow voltage range where they will work properly. Too high voltage and they will burn out and too low and they seem to get dim really fast. Seems like you would almost need 2 leds that would work at different voltages. Sorry I am not more help | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'm just taking a 'shot' here as I had trouble understanding your "bump" response. Could you have wired the "little lights" in series instead of parallel in the parking light circuit?
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Will go check today but I dont think so. I can get the left one to work but not the right. If I change bulbe I get the same result. I did somthing wrong on the re-wire job, just can't find it.The right will work on brake and stop. Just not park/running | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Well, I will try reversing polarity but the brake and stop light portion is working correctly. | | |
