Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#696880 11/21/2010 3:28 PM
Well, my re-wire job is almost completed.
The last hold up is the tail lights. I am using LED's on the rear with little leds in the box rails. EVERYTHING worked prior to my rewire job. The led taillights work ok but the little lights work on Brake and Stop but will not light on Parking lights. They just glow a little. I know this should be sign of a bad ground but the same light works ok on stop and turn. What am I missing here?I have changed bulbs to no avail and checked the power going to the bulb,OK
gazim #696909 11/21/2010 4:44 PM
First of all, you say brake and stop - I'm guessing you meant brake and turn?
Brake and turn are both same brightness so not surprising those work. Just guessing here - I think the LED's need to be designed for the 2 different levels of light. I suspect the LED tails have 2 sets of LED's - 1 for parking, that remains on, the other for brake and turn. I know the taillights are designed to work for both stop/turn, your "little lights" may not be. Don't know how you've wired them so not sure what might be happening. Something to look into until someone more knowledgeable chimes in.
I'm watching this because I get mine back from the painter in a few days and begin to rewire, and I'm using LED's all around.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
The Green Farmer #696918 11/21/2010 5:22 PM
If you are referring to the "brake/turn"lamp and the lamp is an LED. Maybe the LED's do not draw enough current to allow a traditional flasher-tube to work properly.
Some vendors offer solutions for this problem (this reality?) in the way of resistors and/or an updated flasher (for 12v lamps, I do not know if a 6v LED bulb flasher is available for use with 6v LED lamps).
On my 6v positive-ground COE, I plan to place a 6v-12v converter under the dash and use 12v LED bulbs and a 12v LED flasher.
tclederman #697046 11/22/2010 1:17 AM
I mentioned that they all worked properly before I started the wire job/ I have regular bulbs in the front.
gazim #698716 11/27/2010 2:58 PM
bump
gazim #698730 11/27/2010 4:05 PM
Usually leds have a pretty narrow voltage range where they will work properly. Too high voltage and they will burn out and too low and they seem to get dim really fast. Seems like you would almost need 2 leds that would work at different voltages. Sorry I am not more help
1960 Chevy Long Wheel Base
When I die, I plan to slide in sideways yelling "Woohoo what a ride!"
Torker #698763 11/27/2010 7:06 PM
I'm just taking a 'shot' here as I had trouble understanding your "bump" response. Could you have wired the "little lights" in series instead of parallel in the parking light circuit?
beltfed #699275 11/29/2010 3:41 PM
Will go check today but I dont think so. I can get the left one to work but not the right. If I change bulbe I get the same result. I did somthing wrong on the re-wire job, just can't find it.The right will work on brake and stop. Just not park/running
gazim #700149 12/02/2010 4:55 AM
my led tail lamps
LED's are polarity sensitive. Did you swap the wires around?
I used the stock flasher and the stock but changed front parking/ blinker lamps. In other words the front are two filament incandescent bulbs, not one single contact as stock. they are both blinker and pparking lamp. they have enough resistance to make both front and rear leds flash/blinker work.
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-036-16A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-034-15A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-030-13A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=587685-R1-032-14A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=23A-2.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=4472530-R1-019-8.jpg
actually leds have a wide range of voltage.
Jim & Caroline
Well, I will try reversing polarity but the brake and stop light portion is working correctly.
