1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#697940 11/24/2010 11:06 PM
What will fit in the bed roll-over to serve as a custom high mount stop light? I have a 55-2 GMC. I'm a newbe and don't know if I'm in the wrong dept...Thanks .
Bear
1955 2nd Series GMC
More pix in Photobucket
Drive 'em and enjoy 'em.... don't haul 'em....
you're looking for this kinda thing, many of the vendors have them - likely find more info in the 'making a bed' or electrical forums
Thanks squeeze...It's just want I wanted...,
bear
1955 2nd Series GMC
There are also many third brake lights that mount in the rear window.They can be bought at any auto accesory store,very cheap.
I think the vendors have the bed roll lights WAY overpriced. I haven't looked lately but I believe someone wrote an article how to build cheap bedroll lights. Maybe its in the tech tips section.
might be thinking of Alan Horvath, Chip, he didn't have good results .... seems virtually everyone [repro and hot rod sites] sells the pair/kits for $110, so they must all come from one supplier - make your own, check out this thread for DIY ideas
Mar-K has them.I have seen incandescent ones for about $80
I
I Offline
They are not worth it..... not bright enough and to hard to find the bulbs when you need to replace. Spend the extra $30 you will be happy that you did
Check this out. I posted on this subject awhile back.
Robert C.
I'm a Genius in the making.
1950 3600
I made mine using led round marker lights(about 3 inch, ground them down and epoxyed them to a piece of pvc pipe that just seemed to be the right size. Took a little bit of wiggling but they work fine and are bright. for about 3.50 each at the local truck stop. High-po lights?
All great leads ALL....I found another possible is rear red markers from '68 Mopars...
I'll check that truck stop fab too...thanks,
Bear
1955 2nd Series GMC
I guess I was lucky,my Mrs got me mine as a present.These are the HotLites version.
The UK pound was quite strong against the Canadian dollar so they didn't work out too expensive.
I'm using mine as turn signals ,hence the amber colour.
I admit they took a bit of finessing to fit,but I'm pleased with the results!
I'm sure Jim (Carolinestruck) did a tech tip on his. I'll see if I can find it and post it up.
More pix on Flickr.
