7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69855 12/11/2006 8:07 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tractorboy,
Sometimes wires are switched or replaced, so I am not sure how relevant color would be.
Without a voltage tester you are flying blind. The small wire on the side of the starter switch should terminate on a ballast resistor along with the wire leading FROM/TO the + side of the coil.
Some wire should exit the firewall and attach to the other side of the ballast resistor.
Remove the anti-static capacitor until you get things worked out. With the key on and the points closed, you should see around 12 volts to ground on both sides of the ballast resistor AND the + and - side of the coil.
This is a little more involved than just putting brown here and pink there, but it is the proper way to do it.
I don't know if rigs of your era had resistance wires from key switch to coil, but I don't think so...I think you should have a firewall mounted ceramic ballast resistor in line to the coil.
Stuart | | |
#69856 12/11/2006 8:19 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The violet wire should go from the starter side terminal to the + side of the coil so that's wrong but it should run without that anyway. Turn the key on and see if a bulb will light when grounded and touching the coil + terminal. Here's a 1955 wiring diagram that should be close enough. http://chevy.tocmp.com/1955truck2shop/55ctsm1202.htm Try to post in the electrical forum for this stuff and going thru the archives there should help you get every wire in it's place. Good luck. Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#69857 12/11/2006 8:27 PM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Sorry about this list of questions but I'm pretty ignorant on this stuff..
I do have power on both sides of coil as well as bottom of dist but will find out the voltage as you suggested...however, I know not a thing about points...how to tell if they are closed?
Also...where is that ballast resistor located? If I have one,its on the interior side.
last but not least....what is the aniti-static capacitor on the coil for? Radio? | | |
#69858 12/11/2006 8:45 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Pull the distributor cap to see if the points are open or closed. Turn the engine over by hand with the ignition off and you will see the points opening and closing. If the wire from the starter goes to the distributor, it will keep the engine from starting; it must go to the + coil terminal. With the points closed you will read about eight volts on the + coil terminal and zero volts on the - coil terminal with the ignition on and a ballast resitor or resistance wire to the ignition switch in the system. Both coil terminals will read twelve volts with the points open.
The capacitor on the coil is for radio interference. | | |
#69859 12/11/2006 9:31 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tractorboy, Edit my post to indicate what Baldy stated about points open/closed while reading coil voltage...I'm still struggling on this concept! Keep in mind that the points are the switch that make the coil fire the plugs. Everything can be wired properly to the distributor, but if the 'switch' isn't opening/closing properly, then the plugs will never see a big ZAP. A down and dirty test is to pull a plug wire and hold it slightly off a good ground while a friend turns on the key and cranks the engine over. You should see electricity jump the small gap as the plug fires. This basic test tells you that system is intact, although it might need some fine tuning. Stuart | | |
#69860 12/11/2006 10:54 PM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Originally posted by atomarc:
Stuart That clears it up to me...I never really knew what the points did...points may be my problem...If I remember correctly, when I tested the coil (-) side, I had a solid light while the wife hit the foot switch...the light should blink off and on if the points are opening and closing??? right?? | | |
#69861 12/11/2006 11:15 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tractorboy,
I'm a little hinky to answer this outright, so I will say, I 'think' this test might be marginal. Your light might not be a good indicator of what is happening.
Grab your wife again and do the plug to ground ZAP test! This is a go/no go deal!
If you have a gap gauge, it isn't difficult to just set the points and take them out of the equation.
You might do a search in this forum..use the little 'search' icon at the upper right hand side of this page. Type in a phrase like...'points' or 'how to set points' or 'setting points'...you get the idea.
Stuart | | |
#69862 12/11/2006 11:25 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Correct. Put a screwdriver on the points with the key on. You should get a a small spark around the points when you short across them. Each time you break the circuit you should get a spark out of the coil. If you can,t get it started let me know. I might be able to come over & help you. [email protected] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69863 12/12/2006 2:37 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | | | |
#69864 12/12/2006 3:27 PM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Thanks guys..thanks Wrenchbender..this is the one I bought from ya...points look new??
I did a few more checks...I also backed the points out a bit to what I called .016...this I did in "closed" position...
...with the small dist wire (from coil) removed and with the test light clip on the main starter post- I did not get a light when I touched the point wire or coil side points. I did get a light when I touched the backing plate and the point which is connected to the backing plate. I did get a spark between the points when I closed the gap with the tester needle... The light produced by the backing plate remained solid during engine turn over...I then unhooked the condenser and tried again but nothing changed..
...the opposite happens with the small coil wire hooked back up and the test light clip on the frame...I get a solid light at the coil side point but nothin on the plate side...
To answer your question Beaver...I'm not sure about anything at this point : ) I do have the ground strap from the starter to the firewall as well as the cable from (-) battery to the firewall. I also tried a jumper cable clamped to the frame and engine with no change to the test above.... | | |
#69865 12/12/2006 6:05 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | tractorboy,
Whenever I use a voltage tester, I attach the wire with the clip to a good ground, and probe for voltage with the sharp, pokey end. This tells me the connection I have touched has voltage to it.
Using it with the clip to a power source will indicate the point probed has a path to ground. I don't think this is what you need to prove.
Have I misunderstood how you have the tester hooked up?
Stuart | | |
#69866 12/12/2006 8:15 PM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Ok...sitting here at work thinking....I think my points were not closing all the way before I adjusted them and I know they are not closing all the way now...I'll try re-adjusting them tonight.
Ato...I was trying to follow a test from an old post...cant seem to find the exact one now... | | |
#69867 12/13/2006 5:14 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Adjust the points with the point cam follower at one of the high points on the cam. I wondered if you had not done that when I read your penultimate post. | | |
#69868 12/13/2006 5:43 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Baldy, Penultimate! Not bad...one could go a long time without seeing that word. Ato | | |
#69869 12/13/2006 12:28 PM | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | once you get it going, you should check the dwell angle.this checks the amount of time the points are open.You will need a meter for that, i'm not shure where you get them anymore.I have three of them that i get from garage sales and places like that.I use them often,one at work, one at home, one at the cabin.There are many motors around yet with points but not alot of people set the dwell on them. it makes them run a bit better as the time the points are open changes things.Tom | | |
#69870 12/13/2006 1:42 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | K.I.S.S. Run a jumper wire from the positive battery post to the + on coil--wiring complete. Pull coil wire from distributer cap and hold 1/4" from ground, if it arcs spark problems in wiring, if it doesn't problems in distributer.
Evan
#69871 12/13/2006 3:29 PM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Ok...I reset the points...still nothing...so I worked the point arm back and forth with a screwdriver and forced it to close...I had spark !!...got all excited and quickly tried for fire but lost spark after a couple tries...I then cleaned the arm pivit and the actual points....I seem to have consistant spark now .... Still working on fire however : ( | | |
#69872 12/13/2006 10:26 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | What is your point gap? What type of plug and what are they gapped at?
I am assuming that you replaced the condensor along with the points. Just for giggles, put in the old condensor and try it again. | | |
#69873 12/13/2006 11:34 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Have you tried a different coil. When you get that spark at the points you should get a spark out of the coil at the same time. Also check your coil wire. Some of those resister wires can have excess resistance. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69874 12/14/2006 5:10 AM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Thanks everyone for taking time to help out. I have learned a great deal from you guys...  I think I have good spark now...I'm currently dealing with no fire (no engine start), ...I think this is due to flooding from the carb...having hard time finding someone to rebuild mine so I might just go buy a "new" one form Chevy Duty | | |
#69876 12/14/2006 4:07 PM | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Beautiful truck ya' got there Tractorboy!
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#69877 12/14/2006 11:39 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Bring it over Tractorboy I,ll rebuild it. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69878 12/15/2006 12:20 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Not trying to be funny, but is the rotor OK and installed? Had a guy call me once, same problem. He pulled /pushed that truck for miles. Came to me, I went down to look at it and saw the rotor laying on the work bench. ZOOM ZOOM ZOOM. | | |
#69879 12/17/2006 3:16 AM | Joined: Sep 2006 Posts: 42 Junior Member | | Junior Member Joined: Sep 2006 Posts: 42 | Thanks for your offer Wrenchbender....Update...Today was the day!!!...Bought a new carb- messed around with it for a couple hours with no fire...decided everything looked right but since I dont understand points - I decided to mess with them again...man those thing are touchy!!..I moved them a hair in what must have been the correct direction...motor fire right up and purrs...its a beautiful thing!!! Also have been messing with the heater in my down time - it even works now!!!!!!
Not out of the garage yet however...please check out my question on the T5/clutch | | |
