5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#697687 11/24/2010 6:23 AM
I am building a 1956 TF with the orginal 3 spd and plan to put a Disc/drum booster/mc in the OEM spot under the floor. My delimma is how do I access it in the future? I was thinking some sort of trap door. Maybe a battery door from a 47-54 or custom cut and fit one? I know lots of these are in trucks. How did you guys deal with it and how did it work out?
Brad
Mine doesn't leak anywhere so I don't have to access it but once, to fill it. I used this bottle that came with the CPP kit.
Cletis #697706 11/24/2010 8:27 AM
I have the same problem in my AD, I used a turkey baster!
If your system is leak free you shouldn't have to access it too often.
I remove the trans floor panel to get to it if need be.
It's a small inconvenience i'm prepared to live with
More pix on Flickr.
http://www.classicperform.com/Store/1947_59_Trucks/RRCK.htm
This is what I used on my 57 TF Panel, works well and no leaks so far
Don J wave
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
mrduck #697770 11/24/2010 3:02 PM
I cut out the floor above and made a cover (with a little recess). But to refill I would have to remove the seat. I like Don J's solution, I think I will go to that, much more elegant.
Don
Donsz #697990 11/25/2010 1:19 AM
When I swapped to a dual MC, I cut a hole big enough to access, welded a "lip" on the cut out, and 4 corner fastened it in. Here's a couple of pics...
http://img.photobucket.com/albums/v228/Avette4me/My%2058/Brakes/HoleforMasterCyl.jpg
http://img.photobucket.com/albums/v228/Avette4me/My%2058/Brakes/CoverforMaster-mockup.jpg
FWIW, the original plug still fits.
My m/c sits back far enough that I put a new plug in the original hole and then cut me a "oblong' hole in the floor. I will be making a thin sheet metal cover for it. Once the system is finished we should not have to open it up unless there is a problem.
Don J
I think you have the best looking option,where did you mount the resivor?. I am assuming it works on the same gravity fed principal as a hydraulic clutch. Is that right? What about initial purchase cost? Is the CCP a good system and what about customer service?
Brad
Originally Posted by brsdb3381
Don J
Brad
That kit is $89 RRCK Plastic, kit Photo/Info $89.00
Buy
im glad i saw this i was going to ask about the same kit hoepfully we get some feedback
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
http://i131.photobucket.com/albums/p291/mrduckphoto/DSCN1276.jpg
Here ya go...made a simple bracket and mounted it on the firewall. I did this about a year and a half ago when I did the disc brakes and power steering. I do remember having to get some extra tubing to make this work. Any trapped air will rise to the top, keep an eye on the fluid level at first. No leaks or problems yet,but I plan on replacing the plastic resevoir sometime in the future with something I can use metal tubing with. (and might look a little cooler!)
Hope this helps
Don J wave
1964 Chevy Panel
1957 Chevy Panel
mrduck #698283 11/25/2010 11:19 PM
I have a refill bottle just like the one that Cletis has. It is a pita filling it,but if everything is AOK you dont need to refill it anyway.
I bought a generic stainless acess door from Bow Tie Bits for $15.00 to use for a fuel filler in my bed....decided to order another one and use it for the master cyclinder
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
