| | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Anyone replace their stock radiator in a 1951 3100 lately? If so, where did you purchase it? Looking for the best deal I can find. My current one did not hold up to the stress/pressure of start up. Thanks.
Hank
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I bought mine from us radiator I did have a problem when It arrived. The mounting flanges were not welded in the right spot. pic. I called them, e mailed that pic. They had ups at my door the next day to pick it up. 3 days later had the replacement delivered. I was really impressed how they corrected the problem at their cost. I do recommend that company. I believe it is the same radiator chevs of the 40's offers. But less expensive through US radiator. this was on a 1950 3100 235. Good Luck | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I bought a new one a couple years ago from Classic Parts which was the bext deal I could find at the time it fit perfect and works great. You can also make $30-40 just on the brass in your old one at the scrapyard to help offset the cost. | | | | | Joined: Oct 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 75 | I bought the heavy duty from Carter thinking that was the smart thing to do, but its a thicker core and was uncomfortably close to the fan. I'm running a 235 with a short shaft. Plus the mounting holes were off even more than DADS50. Figured as soon as I drilled one hole to relocate, all bets were off on warranty. So I sent it back and had mine re-cored. The radiator shop recommended aluminum (a little cheaper)but I wasn't ready to give up the origonality. Not sure if the standard radiator would have worked better or not.I'm satisfied with the end result but would have been better off re-coreing in the first place. | | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | You can try champion radiators they do all aluminum remakes. USA based company, I think they are made here. Have to double check that. Anyway, they make exact replicas and also a slew of other replicas. They have a limited lifetime warranty, also American Eagle Radiators is pretty much the same thing. You can find both on ebay. I don't think the eagle brand is made here in the states, but the price is about 220 shipped. I have seen quite a few companies out there that make these. Prices from 200-500 and up. I would stick with an aluminum one that has a lifetime warranty. Don't just get the cheapest one out there. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks for the recommendations guys. I will check em' out. I appreciate the advise. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Champion radiators are made in China. I bought two different ones for my 55(210 car) neither fit. But they where good about returning them, even gave me back my shipping cost.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | jivermo, if your a contibutor to the stovebolt be sure and ask for your 10% Stovebolt discount. It does add up. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Don't rule out local rad shops. I had mine re done and they used a heavy duty 4 row forklift core for $250.00 and I could still fit a belt between the rad and fan.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks Curt, got the ol' leak master at a shop right before the holiday, should know something Monday. A re-core might be the best option cost wise as well.
Hank | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I bought a replacement radiator for my 1954 GMC at NAPA, it is a 4 core and fits perfectly. Cost about $300.00 as I remember, it was about 4 years ago. | | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | I just pulled my old Harrison radiator out, and weighed it on an accurate industrial scale. 20.5 pounds. The new one from Classic comes in at 19#. This unit looks real good, and is a precise fit. Standard comes with oil cooler holes and plugs to block them. Here are a series of comparison pics-I'm very pleased. Thye shipped it right out, and we Stovebolters get a 10% discount. Landed cost was 314.oo. Link: http://picasaweb.google.com/Jivermo/55ChevyRadiator310012TonPickup?authkey=Gv1sRgCKff0dKGm_fPOA# | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Fed-X said my old one out of my 53 panel said it weighed 19 lbs. So sounds like everything is pretty much pound for pound! There is a very interesting post here just this past week about radiators..... U.S.Radiators in fact and who they supply and one of the guys from U.S. Radiators made a very interesting post. It was a post initially made by Denny G.
Mine came from Carters a year ago for $295. Chevman32, how long has it been since you ordered yours from NAPA. Do you have that part # handy? I know a friend here locally who is looking for one and don't want to pay the local rad shop 500 bucks to fix the old one. | | |
