2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#69766 12/09/2006 9:28 AM
what is the correct lube for the 4-speed tranny and the rear end in the '58 Apache??
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
mp90
thanks gazim
2 Offline
cjoe you can get it at NAPA.
got it yesterday and all changed all oils. changing coolant today....thanks
for my muncie 420,they say to use gl-4,not gl-5
suzy q antiques,
I think the SM420 and a Muncie 420 are the same thing. The quandary over which gear lube to use has to do with the amount of sulphur (anti-wear) in the product. The brass synchronizers react with sulphur and are eroded.
If you use the incorrect lube, my guess would be that in about 99 years you might see a problem. grin
I believe Novak Transmissions, who deal with this box quite a bit recommend GL-5. This oil thing is Voodoo territory.
Stuart
My manual states SAE 90 multipurpose gear lubricant. Personally, I'm using Lucas full synthetic 75w90, with a 70/30 mix of the Lucas gear oil and Lucas oil stabilizer in the trans.
Bill Burmeister
