0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
My 62 305 has one of these on the factory 3 speed..anyone know anything about these? doing a V8 swap and need to know if it can handle a 350 or if i need to replace it. Suggestions?
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
You mean a hydraulic clutch? Sure it will handle a 350, most modern trucks all have a hydraulic clutch slave to disengage the clutch,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Made me think of my '50 Dodge or Plymouth with Fluid Drive.
Very weird set-up. But, back in 68, everything was kind weird.
my 62 GMC 4000 fire engine with a 351 V6 has a hydraulic clutch and it works great. and NAPA still has the parts for a good price.
RAK Offline
Don't know if this helps but my '61 half ton has the slave set up and a 327 engine.
My 65 C-80 with the 409 has a hydraulic clutch, how stout do you need it?
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
stout enough to handle 400-450 ft.lbs and about 450 hp tops..any way to beef them up? or do i just need to get an entirely new clutch?
All the hydraulics does is move the throw out bearing. It has nothing to do with how much torque the clutch will handle.
BTW-when I replaced the six in my first '62 with a V-8,I found the clutch fork was on the other side of the bell housing. If your bell housing doesn't have the built in pad for the slave cylinder(for V-8/mechanical clutch linkage),it's easy to make one from a little piece of angle bolted to the two upright inspection cover bolts behind the oil filter;drill and thread two holes in it to match the slave cylinder holes. The clutch fork from either V-8 or six set up will work fine. It'll be plenty strong;mine lasted through 3 engines. The hose will be too long;you can either route it to use up the extra length or replace it with a shorter one. I just ran mine up the firewall and back down to the slave cylinder with a loop in it,because it worked fine and I didn't wanna have to open the system and have to re-bleed it,and because I'm too cheap to buy another line.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
