1 members (Paul Mullen), 109 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#694237 11/12/2010 7:33 AM
Members:
Note- New truck for me
I have an air flow heater in my 54 3100. I have a cable that is labled " T " that operates the flap door on the heater( on the side - to recirculate the cab air).
I have an under dash switch looks aftermarket. I have 2 hoses going into the heater from inside the engine compartment, off the water pump...But I don't see a on/off valve inline on one of the hoses ?
Does the water just circulate thru the heater..then when i need heat/defrost the switch turns on the squirrel cage and thats when I feel the heat ?
The heater hoses look new...did the last owner forget to put the valve back on ? or does the 54 not have it?
Thanks Guys
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
There should be a valve mounted to the firewall. It is called a Ranco valve. You could use an in-line valve.
It's possible that the previous owner left off the valve because it leaked or something. There should be a valve mounted to the inside of the firewall that protrudes into the engine compartment where hoses attach to it. Like cletis said, it's called a Ranco Valve.
The baffle in your heater only diverts the airflow to either the floor or defroster outlets. It does not recirculate the air.
To operate your heater you turn on the fan, adjust the flow of water to control the amount of heat coming out of the heater, and select heater or defroster as desired.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
On a further note the "T" cable is incorrect the knob should look like the headlight knob with a white dot someone has substituted a throttle cable for it. Here are some pictures of exactly what you should have:
http://good-times.webshots.com/photo/2997794690102454676zVyDRw
First picture shows Ranco valve/heater w/correct knob
http://good-times.webshots.com/photo/2738738300102454676GDFfat
This shows how it looks under the dash (this is a 49) but shows the bracket/tube attachment (missing black knob).
Here is how the hoses look from the firewall side.
http://good-times.webshots.com/photo/2923223350102454676TQPsWQ
Hope that helps.
Woody:
I saw the lever on the fan housing that diverts the air flow to floor or defrost....whats the purpose of the tall skinny flap door if not to draw cab air back in....it's drawing air on the back side of the squirrel cage. I'm Just guessing .
Jimmi
Jimmi V.
Brad :
Thanks for the pics.. I understand the knob is wrong...but where can I find the correct lever cable ? Also, My engine compartment looks like your pic,only my hoses are alittle lower and to the left. They connect to 2 tubes. On the inside I don't have a straight rod that is connected from dash to back of firewall....is that the on/off valve ? I just have a switch.
thanks
Jimmi V.
I would imagine most people buy a plain knob to add to a choke or heater cable I don't know of anyone reproducing the original. Your hoses are just hooked directly to your heater because the valve is missing if you are looking to make it correct you need to run it through the Ranco valve as shown. The bad news is the Ranco valves and repro knobs are available but the other pieces are not reproduced so Swap Meet or eBay is your option. This valve assembly is and early attempt at temperature regulation in the cab not just on/off. When I have sold heaters in the past I include all these various little parts because of the difficulty in finding them.
Originally Posted by Jimmi_V
Woody:
Jimmi
Yours must be a newer model or something because mine doesn't have that flap. Sorry for the mis-direction.
Woody
Door Art Collection
When that flap is open the inner flap is closed and cab air recirculates. When that flap is closed the inner flap is open to allow outside air into the cab.
The earlier models of that style heater were call "fresh air" because outside air was moved through the heater at all times.
The 53-55 models of that heater had the door/flap on the front for recirculating interior air and were called "air flow". That flap/door operates as Cletis describes in the previous post. Look at the illustration and you can see that it shows a partially open flap/door (recirculating a little inside air and letting in a little outside air).
Several years ago, the "new owners" of GSPP - Golden State Pickup Parts kindly found me a correct length/knob 54/55 control cable for this style heater (a reproduction cable/knob that they might have made for me?).
Tim:
May I ask the Name & where you got the manual your pulling info and pics from, looks really helpful
Thank
Jimmi V.
Jimmi,
I probably bought that 1954 Chevrolet Truck Accessories brochure off eBay about 8 years ago.
It is one of several documents listed on my website.
9
9 Offline
You can get the heater temp control knob and Ranco valves from Classicparts.com You can pretty much get all the heater stuff from them. There are a couple things they don't have, such as the rubber grommet that cover the heater motor as it sticks out of the cab slightly.
anyway, I have a 350 in mine, I am running the Ranco valve. I believe I have a heater hose coming from water pump to the far left of the heater core. Then coming from my intake I have a heater hose going into the back of the Ranco valve, then a hose coming from the front of the Ranco valve into the Right hand side of the heater core. Basically there are two slots on the heater core and two slots on the Ranco valve for your hoses. You have two slots on the engine, water pump and intake.
Same concept for inline 6 engines, I have a 54' all original too. The heater is is just a blower motor that is controlled by
electric, the heater core is where the water comes into and the blower just blows that hot air, that is controlled by you and or the Ranco valve opening and closing, also you can control it to cab or defrost. again check out classicparts, they also have 12 volt motors and also power inverters for using 6v motors with 12v systems.
Only thing I don't know is where the copper wire from the Ranco Valve goes to, I thought it might go to the motor but I am not sure if it is long enough. Does anyone know what I am talking about?
51' 3100 s10swap, 350, 5 speed, patina
http://67-72chevytrucks.com/vboard/showthread.php?t=382481
49' GMC 3100 future project
55.1' chevy future project
54' 6400 chevy dump truck all original
63' c-10 future project
That copper "tube" sort of half curls and lays next to the firewall right above/beside the tranny hump.
Denny Graham has a pic of it in his photo album but I don't have a direct link right now.
Here is a picture of a never modified original truck and the tube location.
Dear 99:
I can't find the ranco valve at Classic parts..they only service your valve for you...also, I can't find the dash mounted rod that controls the ranco valve ( see Brads pic)..... Anyone know who carries that stuff ?
also, Tim I just ordered a accessory & owners manual to go along with the one I already have...
Jimmi V.
Jimmi V.
Jimmi V
Try posting in the parts wanted section of this forum. I had good sucess posting there.
Good Luck
What about here. for valve?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
9
9 Offline
jimmi,
yeah I guess classic parts only services the valve. I thought you can buy one but you have to give them yours as a core charge. Anyway, maybe these aren't being reproed rather just refurbished. I would call that Jim Carter place, it still seems iffy if you can just buy one. I did see a valve on ebay completely redone for about 70 or 80 bucks.
Well, my valve leaks and my heater core leaks, so I went ahead and ordered up the aftermarket heater box, comes with everything you will need to run it, I mean everything. I am just going to run a shut off valve so in the summer I won't let hot water in and winter it will always be running through.
Lastly, I know what you mean about hat rod that connects to the Ranco valve. I have mine, but I don't have the "dash" attachment, I guess you can't find everything aftermarket. So yeah gotta keep it old school and hunt for it.
try
http://www.heatervalves.net/
He rebuilds Ranco Heater Valves.
sells a few rebuilt valves with no core required
used rods and brackets also.
Good Luck
