4 members (Otto Skorzeny, Barry Martak, Hawkman, stlcardinalsguy), 108 guests, and 2 robots.
Topics128,088
Posts1,056,414
Members48,443
#692752 11/07/2010 2:47 PM
Hello all!
I installed a soft rubber gasket on my cowl vent opening. I know I have it installed correctly but I'm not happy with it. It makes the cowl vent sit a little higher than I like. Does anyone know of a better gasket? Also where can I find the correct shoulder bolts for the vent bracket?
Thank you! APV
Give the gasket a little time, it should smash down a little letting the door set flush. I think you have to make the shoulder bolts yourself.
Joe
APV60...first you said SOFT rubber gasket so it may lay down like Joe suggest. BUT, I put a rubber gasket on my 37 10 years ago and it has yet to lay down. Its always up a bit. So, I ordered me one that is either a foam type or cork....can't remember as its been laying on a shelf for a long time. Maybe I'll change it this winter??
Thank you both for the response.
Last edited by cletis; 11/08/2010 2:29 AM. Reason: Removed response to parts offer
If its any consolation, mine sticks up as well....been almost 3 years with no settlement. I have a spare - perhaps I will try cutting it down a little.
1940 Chevy KC 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
The new gasket on my 38 fits perfectly. I wonder what the difference is since they are the same. Hmmmmm.
Tiny #693218 11/08/2010 11:42 PM
Tiny, I bought the one that we're complaining about long time ago. Plain simply fact is the rubber gasket I got then was, and still is, to THICK and to HARD. As I mentioned earlier, I have another but just have not put it on.
It was "advetised" back then as better than the old cork ones but hey, better is not always better!!
