1 members (Hotrod Lincoln),
55
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Hello all! I installed a soft rubber gasket on my cowl vent opening. I know I have it installed correctly but I'm not happy with it. It makes the cowl vent sit a little higher than I like. Does anyone know of a better gasket? Also where can I find the correct shoulder bolts for the vent bracket? Thank you! APV | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | Give the gasket a little time, it should smash down a little letting the door set flush. I think you have to make the shoulder bolts yourself.
Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | APV60...first you said SOFT rubber gasket so it may lay down like Joe suggest. BUT, I put a rubber gasket on my 37 10 years ago and it has yet to lay down. Its always up a bit. So, I ordered me one that is either a foam type or cork....can't remember as its been laying on a shelf for a long time. Maybe I'll change it this winter??
| | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Thank you both for the response.
Last edited by cletis; 11/08/2010 2:29 AM. Reason: Removed response to parts offer
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If its any consolation, mine sticks up as well....been almost 3 years with no settlement. I have a spare - perhaps I will try cutting it down a little. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The new gasket on my 38 fits perfectly. I wonder what the difference is since they are the same. Hmmmmm.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tiny, I bought the one that we're complaining about long time ago. Plain simply fact is the rubber gasket I got then was, and still is, to THICK and to HARD. As I mentioned earlier, I have another but just have not put it on.
It was "advetised" back then as better than the old cork ones but hey, better is not always better!! | | |
