1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
This is the Master Cylinder on my 57 6100
http://skitch.com/donnoman/d9nhx/volumes-no-name-dcim-155canon-mg-5513.cr2-ufraw
Does anybody have a drawing from a service manual that covers it?
Can I get a replacement, or should I be looking for a rebuild kit?
Any suggestions on sourcing the parts?
Any suggestions on getting a kit/tools to re-do the brake lines?
57 Chevy 6100 Wrecker http://donovanbray.com/tag/57wrekr
OK, looks like this is just the hydrovac unit, I guess the master cylinder is elsewhere.
I found a good walkthrough here, http://www.stovebolt.com/techtips/bendix/erickson/, but still need a source for parts.
The master cylinder is under the floor board. Look for the round hole in the floor, just back a few inches from your right heel. You can find a new master cylinder for a little over a 100.00. If its not to pitted you can get a kit for 25.00 to 30.00. If you get a shop manual for your truck it will show you a diagram of all the parts inside it.
Rebuilt Hydrovac's are still available from NAPA. I'm not sure if the Master Cylinder is still available or not, but you can have your MC sleeved and rebuilt making it better than new for less than $100...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Online manuals by our friend Keith Hardy may be what you need.
http://chevy.oldcarmanualproject.com/
Big Bolt Forum Co-moderator
Make sure your aluminum casting is still good. Mine had corroded so badly the ears that hold the J-hooks were like cheese. I bought a new unit for $388. http://vehiclesofvictory.com/buying-selling/reproduction-to-parts/
You have to change over the fittings if you want to keep your hard line instead of a rubber fitting.
1948 Chevy 2-Ton
