5 members (FishinToms53, Toadwart, dt235sd, 2 invisible), 73 guests, and 1 robot.
Topics128,087
Posts1,055,999
Members48,430
#682588 10/02/2010 1:00 PM
what rear end will fit my 53 3100 pickup
Please any help will be greatly appreciated
ODSS Lawman
ODSS Lawman
The easy answer is any, depending on how you want it to look.
The better answer takes some answers of some general questions. What are your goals for this truck? Highway cruiser, boat hauler, gravel carrier?
Is the rear in your truck good now? I did the 3:55 gear replacement and have had a lot of success with it. Check out the album on my Webshots page.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #682595 10/02/2010 1:49 PM
i just want a cruiser wont be hauling any thing want the hot rod look but not to extencive just a nice looking low riding truck inexpencive
Then the rear end ratio won't make much difference. I went to 20in wheels and changed the rpm a bunch. a different rearend won't effect the height. The front however is a different deal alltogether.
gazim #682606 10/02/2010 3:21 PM
i want to go with open drive shaft
Z
z48 Offline
Z Offline
I have a 48 chev and I put a 1980 diff out of a camaro, springs and all. a little wide, but I have corvette reversed rally,s on the back end Doug
z48 #682668 10/02/2010 9:22 PM
When I had my '52 1/2 ton I used '72 Nova. Just like Z48 says, the mouting pads are a little too wide, but it will drop in. I think I flipped the springs around to center the axle in the wheel wells, but can't remember that exactly.
I used 1969 Corvette L88 rally wheels. 15x8s I seem to remember. Looked awesome!
52Dave3600 #682747 10/03/2010 2:40 AM
all sugestion are great but would like more options. PLEASEHELP im a newbee
I have a 56 w/ a 350 small block & a 400 tranny. I put a 3.08 posi rear end in mine so I could cruise at 65 running about 2200 rpm's. You'll want to consider tire size as well. I found that Randy's Ring & Pinion web site to be very helpful. Their calculator tab at the top will assist you with determining what you might want. That said, it won't tell you which rear end you need, but it will start you on the right path.
http://www.ringpinion.com/Default.aspx
Paul
1956 Chevy Task Force Webshots
My wife puts knots on my head faster than I can rub 'em. That's why I ask knot-headed questions.
How many more options do you want?
Any other options start becoming big money and/or challenging to install.
I once saw a guy that installed a Chevelle rear end. It looked like alot of work. He installed the swing arms and everything. He built gliders for a living and was a master fabricator.
The cheapest & easiest by the way would be to use a 68-to early 80's Camaro/Nova rear end.
52Dave3600 #683258 10/05/2010 1:53 AM
Thanks for all the info i need it im a real green horn at this!
I have a 53 3100 and used an 85 camaro posi rear , mine has drum brakes, and it fit perfect,, lokar makes the e brake cables and steve at buffalo makes the saddles for the rear to set on the springs ,, my gear is 3:23, good cruiser on the hiway
Originally Posted by carolines truck
Want to know about swapping out a rear end.
and what to use Here's food for thought.... on 50’s chevy’s By: Jim Forbes
The 82-newer Camaros are wider than the older ones, so you should stick with the 70-81 models. The 75-79 Nova uses the same rear as these older Camaros, I believe. The 68-74 Nova chassis is the same as a 67-69 Camaro; the 75-79 Nova chassis is the same as the 70-81 Camaro. The 82-newer Camaros used the small 7.5" rear-end design that the 78-newer Malibu/Monte Carlo/regal/cutlass etc used, but it's quite a bit wider. Some of the 82-newer Camaros used different rear ends, such as the Dana 44, and some weird Australian rear-end. Of course, if you want to make sure, get out your tape measure and check yourself! I may be wrong.
Here's another one from Jim on the subject---- There are lots of rear ends available! Some fit better than others. For 6 lug rear ends, the 64-69 1/2 ton 2wd Chevy (and some GMC) trucks have a 12 bolt rear, about 60-61" wide (I measure them where the wheels bolt on). The 70 2wd and 70-81 4wd have a 6 lug 12 bolt that is a couple inches wider, but will fit under an Advanced Design or Task Force truck as long as you don't get too wild with wheel/tire width. The heavy duty models have a 2.75’’ brake shoe, that’s stopping power. The 12 bolt truck rear ends from the 60s usually had 3.70 gears, which is a bit much for extended highway driving at 75 mph. You can swap the differential carrier and ring/pinion gears from a later TRUCK or VAN 12 bolt, the 70s trucks usually had 3.08 or 3.40 gears. Of course, you'll need to know how to set up ring/pinion gears, bearing preload, and all that other neat stuff to do this. These 60s truck 12 bolt rear ends are from coil spring trucks, so the perches are in the wrong place, and they have some extra stuff on the housing for a panhard bar, which you won't need with leaf springs. Most 60s GMC trucks, and some Chevys, had Dana 44 or Dana 60 rear ends, and leaf springs. These rear ends are 6 lug, about 60" wide, and will bolt into a Task Force truck (with some fudging, the perches are about 1/2" too far apart). The brakes use different parking brake cables, which is a problem, and the drums have a different offset. Gear ratios range from 3.21 to 3.92 normally, the 3.21 is found behind some GMC V-6 engines, and is a nice ratio for an old truck. The Dana 44 uses a standard Chevy 1310 yoke, but the Dana 60 uses a heavy duty yoke, which takes a larger 1350 series ujoint. A similar Dana 40 rear-end was available as an option in 59 Chevy trucks, equipped with positraction...rare, and with a 3.92 ratio. I have one of these rear ends; it was in my extended cab truck...I'm saving it for when I build a race truck (one of these years).
The 71 and newer 2wd trucks use a 5 lug 5" bolt pattern, same as the 71-76 full size cars. There is not much available in the way of matching front brake rotors that will fit an old truck, so this rear-end is not too popular a swap, unless you get the 70-up 4wd 6 lug axles. Chevy also used 10 or 12 bolt rear ends in lots of cars, in varying widths. The heavy duty models have a 2.75’’ brake shoe. A common one is the 61" wide 70s vintage Camaro/Chevelle/Nova (and clones) 8.5" rear-end. In Camaros/Novas it has leaf springs, but the perches won't work with old truck springs. In Chevelles, it has coil springs, with lots of extra brackets to cut off, and the cast in mounting "eyes" on top, where the upper control arm bushings fit. Wheel bolt pattern is 4.75", and there are front disk brake kits available to match, or you can use the 53-54 car front hubs/drums on the original 50s truck brakes, to get the same bolt pattern front/rear. This is a good rear-end for using in an old truck, the ratios are commonly 2.73-3.36, with higher gears available. The axle shafts are usually worn out in these things, so check them (pull the cover, lockpin, and C clips out to get them loose) where they ride in the wheel bearings...before buying the rear-end! The 55-57 Chevy car rear-end is almost a bolt in, the perches need to be relocated to the top of the housing though. It has the 4.75" bolt pattern, and ratios are usually 3.55-3.73, but sometimes you'll find a 3.36. The 78-88 mid size GM cars use a 7.5" 10 bolt, which is about 58/5" wide. This rear-end would work well in an early (older than 47) truck, but it is quite light duty. Ratios are usually 2.29-3.23, which means you want some torque in the engine to pull it...but rpm will be low. This is a coil spring rear-end, with all the mounting brackets that need to be cut off. The Ford 8" and 9" rear ends come in a whole bunch of varieties, and only a few are useful in oletrucks. The late 50s full size cars have a nice one, but it's not easy to find brake hardware, drum, etc anymore. The mid 60s midsize cars, such as the Fairlane, have a rear-end that is about the right width, and would be a good candidate...if you can find one. The Maverick/Granada is very narrow, about 56.5", and would not fit anything but a very early truck, or perhaps a tubbed Pro Street truck. The 60s full size Ford car rear ends are usually too wide, but if you find one, measure it and see! Most earlier full size, and all mid size, cars use the 4.5" bolt pattern, while later full size cars use the 5" pattern. The Ford trucks have a big 5 on 5.5" pattern, with a big center that takes some work to redrill to anything Chevy. Ratios range from 2.47 to 4.30, and the axles come in 28 or 31 spline varieties. There is lots of interchange possible with the 9" rear-end, which is why it's so popular...I have one in my 55 Belair, and in my 57 Suburban chassis. Unfortunately, they are getting expensive, especially when you have to shop around for just the right one that will fit. So...if you don't know if a rear-end will fit, or what it came from, get out your tape measure and see for yourself! The most important things are overall width, and wheel bolt pattern...then concern yourself with ratio. I like a 2.75-3.0 ratio for a V-8 powered truck that will spend lots of time on the highway; about 3.2-3.7 for a 6 cylinder or small V-8 for in town and limited highway use, and the stock 3.9-4.56 ratio is great if you have to use your truck to haul lotsa weight, and you don't have much engine...just don't plan on going much faster than 55!
[color:#CC0000[size:14pt]]http://www.chevytrucks.org/tech/[/color]
GENERAL: ELECTRICAL:
Chevrolet Restoration Pack
Generator Info
How to decode an AD VIN number (3)
Brake Switches - Mechanical or Hydraulic?
Model numbers (Advance-Design models)
Gas Gauge Troubleshooting
Overdrive/MPG
Wiring diagram for a 58 1/2 ton (off site)
How to store your truck for the winter
Stuck Bolt Removal
MECHANICAL:
Truck Values
Huck style brake conversion to bendix style (4)
How to install hubcap clips
Engine Identification
Replacement seats for you trucks interior (2)
Brake Bleeding-there is a correct way
Automotive Calculations
Loads of info of IFS and rear end swap (2)
BODY: Installing an S-10 T-5 transmission in an older truck
Bed Wood Dimensions for 1947-1951 and 1955-59 Models
Pacer IFS Installation in a Chevy Truck (5)
Adjusting the hood on the AD trucks
Installing a GMC 302 motor in a 1950 Chevy pickup
Deluxe Cabs
Swap your 216 for a 235 (off site)
Door Spring Installation (Advance-Design Models)
Rebuilding an Inline "Stovebolt" Six
Tool Kit Contents in an Advance-Design Truck
Lowering the front of your TF truck (2)
Gas Tank Cleaning
3 speed to 4 speed automatic conversion on a TF truck (2)
Insulating A Cab
Powering Steering install on a TF truck (2)
Paint Colours for Body & Engine
Steering Boxes and Proper Lubrication
Paint Stripping Methods
Adjusting the steering box (8)
Seat Cover Replacement
Torque Tube Drivelines
Task-Force Cab Step Replacement
Rear end swap and what to use
Seat Belts in Vintage Trucks
Remove/Reinstall "Stovebolt" Cylinder Head
Building stake bed sides to your step side bed
How to install a 63-87 IFS in an AD truck (3)
Windshield Wiper Replacement
Inline Manifold Seating
Decoding the serial number on Canadian GMC TF trucks (1)
Rear Main Seals for 216 Engine
U.S./ Canadian TF model cross-reference guide
Tie Rod End Replacement
Dashboard Replacement in Task-Force Models
Short/Long water pump-which one do I have???
Adjusting the door latch and striker plates (off site) (7)
Crankshaft Durability
How to install a Fulton Sunvisor (off site)
47-53 3/4 ton rear end replacement (6)
How to build a cab dolly
Engine Block Terminology
Stuck brake drum (it won't come off)
Implanting a 82 monte carlo IFS on an AD truck (9)
Info on the AD-S10 frame swap
Under the bed spare tire carrier for AD trucks (10)
Disc brake upgrade for TF truck
GEAR RATIOS :::::::::::::::::::::::::::::::::::::::::::
1951 Delux Chevrolet 5 Window Pickup
Tire Diameter : 28 inches
Rear Gear Ratio 2: 3.40:1
MPH @ 3:40 ring & pinion
RPM 1st 2nd 3rd 4th 5th 6th
1000 8 12 18 24 32 0
1500 12 18 26 35 48 0
2000 16 24 35 47 64 0
2500 20 30 44 59 79 0
3000 24 36 53 71 95 0
3500 28 42 61 82 111 0
4000 32 48 70 94 127 0
4500 36 55 79 106 143 0
5000 40 61 88 118 159 0
5500 44 67 97 129 175 0
6000 48 73 105 141 191 0
6500 52 79 114 153 207 0
7000 56 85 123 165 222 0
7500 60 91 132 176 238 0
8000 64 97 140 188 254 0
MPH @ 3:43 ring & pinion
1500 12 18 27 36 48 0
2500 20 31 44 59 80 0
3000 24 37 53 71 96 0
3500 28 43 62 83 112 0
4000 32 49 71 95 128 0
4500 36 55 80 107 144 0
5000 40 61 89 119 160 0
5500 44 67 97 131 176 0
MPH @ 3:73 ring & pinion
1000 7 11 16 22 29 0
1500 11 17 24 33 44 0
2000 15 22 33 44 59 0
2500 18 28 41 55 74 0
3000 22 34 49 65 88 0
3500 26 39 57 76 103 0
4000 30 45 65 87 118 0
4500 33 51 73 98 133 0
5000 37 56 81 109 147 0
5500 41 62 90 120 162 0
MPH @ 4:11 ring & pinion
1000 7 10 15 20 27 0
1500 10 15 22 30 40 0
2000 13 20 30 40 54 0
2500 17 26 37 50 67 0
3000 20 31 44 59 80 0
3500 23 36 52 69 94 0
4000 27 41 59 79 107 0
4500 30 46 67 89 120 0
5000 34 51 74 99 134 0
5500 37 56 81 109 147 0
Suspension Measurements
REAR SUSPENSION:
The following is a general list of rear ends and their dimensions to help narrow the search for a possible candidate to replace the torque tube rear end or just get a better set of gears for highway driving.
Advance Design Trucks seem to be using rear ends with widths ranging from 58"- 62". I'm not sure of the Task Force width ranges at this time.
Contributing information were Bob Welch, J Forbes and various locations throughout the Web and Automotive Magazines.
Rear Axle Measurements
MEASURED ACROSS WHEEL MOUNTING SURFACE
56 1/2" 71-77 Ford Maverick 8",
57" 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9"
57 1/4" 64 1/2 - 65 Mustang
58" 78-88 Mid sized GM Car, Malibu/Monte Carlo (82 up Metric Studs), 80 Granada & Lincoln Versailles,
67-70 Mustang/Cougar/Fairlane, Regal with 10 bolt axle, S-10 P.U., 65-67 Nova
58 1/2 " Ford Grenada
59" 68-83 Corvette
60" 55-64 Chevy Car, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 71-73 Mustang/Cougar, 84-95 Corvette
60-61" 64-69 1/2 ton 2wd Chevy/ Some GMC 6 lug rear end 12 bolt Coil spring set up Possible gear ratio's 3.70
62" 64-77 Chevelle, 73-76 Torino, 89 Trans Am,
70 2wd 6 lug rear end 12 bolt Possible gear ratio's 3:08, 3:40, 3:73
70-81 4wd 6 lug reared ...............................................................
71- Newer 2wd trucks use a 5 on 5 lug pattern
71-76 Full Size Cars " "" "" "
60" 60's GMC and some Chevy's Dana 44 or Dana 60 with leaf springs 6 lug, Gear ratio's 3.21 to 3.92. GMC V-6 used a 3.21 Dana 44 used a standard chevy 1310 yoke, Dana 60 used the heavy duty yoke which takes the larger 1350 yoke.
Approximate rear end widths measured from backing plate to backing plate.
Add Width to compensate for drums as follows:
4" - 5" for small cars 5" - 6" for intermediate cars 6" - 8" for large cars
48" - 49" 50" - 51" 52" - 53"
'71 Colt
'72 Cricket
'72-75 Datsun Pickup
'72-73 Mazda '65 Ram American
'74 Valiant '28-40 Ford , '57 - 59 Ford
'62 Buick Skylark, '67 Chevrolet Six
'67 Mustang Six , '68 AMX
'69 Javelin Six , '70 dodge
'70 Duster , '71-77 Maverick
'71 Comet , '71- 72 Pinto
54" -55" 56" -57" 58" - 59"
'39 -48 Chevrolet, '68 GTO
'41 -48 Ford, '68-72 Chevelle
'55 -57 Chevrolet, 68-69 Fair lane 6 or 8
'66 Falcon, '69 Chevrolet
'67 Mustang V-8, '69 Firebird
'69 Cougar, '71 -73 Nova
'73 Ventura, '73 Mustang '36 Plymouth, '54-56 Ford Pickup
'67 Lincoln, '69 Dodge
'69 Dodge Van, '71 Torino
'72 Cougar, '74 Pontiac '49 Plymouth, '61 Chevrolet Impala
'65 Cadillac, '66 Buick Wildcat
'66-67 Chevrolet Big Car, '72 Charger
'69 Oldsmobile 88, '72 Chrysler
'72-73 Torino
STOCK CENTER TO CENTER SPRING PERCH DISTANCE
25" 39" 42" 42 1/2
'68 - 72 Chevelle '71 Colt
'73 Mazda '68 -71 Fairlane/Torino
'49-51 Ford '69 Chevrolet
'69 Nova
'71 - 72 Pinto
'73 Ventura
43" 43 1/2" 44" 46 1/4"
'65 Ram American
'64 1/2-'65 Mustang
'67 Mustang
'70's Ford Grenada
'69 Firebird
'70 Dodge '71-77 Maverick
'70 Duster
'70 Nova
'71 Comet
'72 Dart
'72 Cougar
'74 Valiant '57 Ford
'67 Chevrolet Six
'68 AMX
'69 Javelin Six '69 Dodge
47 1/2" 48" 51" 57 1/2"
'39 -48 Chevrolet
'67 Chevrolet big car
'72 Charger
'72 Chrysler '69 Dodge Van
'69 Ford Van '67 Lincoln
BACK TO TOP OF PAGE
The following list of extensive information was contributed by R. Welch:
Original Vehicles
Rear Suspension Width (Flange to Flange)
Year Classic Vehicles Width
26-39 Plymouth-Dodge car/pick up 56-58"
40-52 Plymouth-Dodge car 60-62"
26-39 Chrysler/DeSoto Car 60"
Most Early Mopar's 56-62"
25-39 Chevy Car 56-58"
26-46 Chevy Truck 56-58"
40-48 Chevy Car 58-60"
49-54 Chevy Car 58-60"
47-54 & 55 1st Series Chevy Truck 60-62"
Most Early Buick,Olds, Pontiac 58-61"
28-31 Ford Car/Pickup 57 1/2"
32 & 33-34 Ford Car/Pickup 56 1/2"
35-48 Ford Car 57-60"
35-41 Ford Pickup 56-60"
49-58 Ford Car 57-58"
49-56 Mercury 57-58"
49-51 Mercury 61"
64 Falcon 58"
67 Cougar 60"
55-59 Chevy Pickup 62"
Donor Vehicles Front and Rear
Year Classic Vehicles Width Front Width Rear
74-79 Ford Mustang II/Pinto & Mercury Capri/Bobcat 55 ½" 55 ½"
71-77 Ford Maverick with 8" axle 56 ½"
75-80 Ford Granada with 8" axle 57 ½"
64-66 Mustang 57"
67-71 Mustang 59"
72-73 Mustang 60"
67-69 , & 60" Camaro 60"
64-67 Chevelle 60"
55-64 Chevy car 60"
65-67 Nova 58"
68-72 Nova 60" 60"
78 & up Monte Carlo, Regal, etc. with 10 bolt axle 58" 58"
68-72 Chevelle with 10 bolt axle 61 ½"
89 Trans AM (Disc brake) 62"
76-80 Camaro/Firebird 61 ½" 60 ½"
68-83 Corvette 58 ½" 59 ½"
84-95 Corvette 59 ½" 60 ½"
Early 70's "A" body (Dart/Duster) with V8&3/4 axle 58"
"E" Body (Cuda) with V8&3/4 axle 58"
Dodge Dart 59" 55 ½"
Plymouth Volare & Dodge Aspen 61" 60 ½"
71 Blazer (6 lug) 63 ¾"
75-78 Granada 9" (43" perch to perch) 52 ¼"
75-78 Maverick 9" (43" perch to perch) 56 ¼"
81-87 Olds Cutlass 58 ½"
FRONT SUSPENSION INFORMATION
Track Width of Popular Donor Car Clips
Manufacture Model Years Track Front/Rear Curb Weight
Chevrolet Nova 68-74 59.8-59.6 3,770
Buick Apollo 68-74 59.1-58.8 3760
Pontiac GTO 68-74 59.9-59.6 3880
Chevrolet Corvette 68-83 58.7-59.5 3655
84-95 59.6-60.4 3890
Chevrolet Camaro (Z28) 76-80 61.3-60.5 3820
Pontiac Firebird (TA) 76-80 61.3-60.5 3900
Ford Mustang II 74-79 55.6-55.8 3305
Pinto 74-79 55.6-55.8 3305
Mercury Capri 74-79 55.6-55.8 3305
Bobcat 74-79 55.6-55.8 3305
Chevrolet Monte Carlo 78-86 58.5-58.8 3235
Buick Century 78-86 59.0-58.8 3700
Pontiac Grand Prix 78-86 58.9-59.0 3735
Plymouth Volare 75-79 61.0-60.5 3395
Dodge Aspen 75-79 61.0-60.5 3395
Dodge Dart 76 59.2-55.6 3600
Table taken from "How to Build a Custom Classic Truck" Peterson Publication; June or July 1999
Written by: Don Emmons & Mike Briggs
enjoy your week's reading
cheers
jim
Jim & Caroline
now thats a 1/2 ton of info!
Thanks John grin
' Offline
John,
I had a 53 chev pu and put in a 70 ford f100 rear end. What's nice about them is they are extremely strong and it is a snap to change the gears out if you want another ratio. It's 61 1/2" from the left/right axles. It's 61 3/4" from mounting surface to mounting surface. When you do this you will have a 5 1/2 inch bolt pattern with 5 1/2" bolts. Solution is to either get multi lug wheels from someone like Stockton Wheels which will fit both the chev front and the ford rear. For other modifications let me know.
' Offline
Also, you can have your 5 1/2 inch bolt pattern changed to match your front end by someone like Dutchmans Motor Sports in Portland. The stock saddles mounted on the ford f100 axle can be used where they are originally as the spacing is correct for your rear leaf springs. You will, of course, have to have a new drive shaft made.
Enjoy,....Dan
52Dave3600 #686640 10/16/2010 2:07 PM
I have a 79 nova with 2.73 gears. a little low in hilly country but ok here in Indiana. i have a 89 T-5 trans with overdrive 5th gear which in hilly country i have to use 4th on long uphill runs at highway speeds. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Enjoy,....Dan
Hey Dan,what ratio is this rear and to make this drive shaft do i just marry the back half of a ford to the front half of a chevy.
Thanks John
johns truck #692390 11/05/2010 11:26 PM
k10 Offline
I have a 12 bolt from a '65 Chevy truck. It's going under my '51 GMC Suburban. What would be the preferred method of setting up the parking brake cables? The originals are toast. The burb has the big bar going across the frame to get both cables to actuate.
k10 #692881 11/07/2010 9:52 PM
I use.d a Lokar kit and attached onto the rear disc brakes. Works perfectly
http://s729.photobucket.com/albums/...ction=view&current=EBrakeCable-2.jpg
~Jim
to answer your question
i used a 1977 suburban 4x4 rear end in my 3100. i have 3.40:1 ratio. a T5 Hybrid tranny, ..... camaro guts in an S10-15 sonoma T5 housing. a 292 motor
she pulls fine up hills as we live at 2500' elevation.
the brake shoes are 2.75 '' wide
Jim & Caroline
Jim & Caroline
I Have a 57 Chv1/2 Ton Pick up I want to Swap the Rear End out for a High Rpm Gear Ratio Mye Is 62" wide 6 Lug What well Work and what Gear Ratio do I Need
Hope this helps
Information provided by:
Joe Garcia
The Resto Rod Shop
REAR SUSPENSION:
58" 78-88 Mid sized GM Car, Malibu/Monte Carlo (82 up Metric Studs), 80 Granada & Lincoln Versailles, 67-70 Mustang/Cougar/Fairlane, Regal with 10 bolt axle, S-10 P.U., 65-67 Nova 58 1/2 " Ford Grenada
59" 68-83 Corvette
'71 Colt
'72 Cricket
THESE SHOULD FIT '49 Plymouth, '61 Chevrolet Impala
'72-73 Torino
25" 39" 42" 42 ½"
'69 Nova
'71 - 72 Pinto
'73 Ventura
43" 43 ½" 44" 46 ¼"
'65 Ram American
'64 1/2-'65 Mustang
'67 Mustang
'70's Ford Grenada
'69 Firebird
'70 Duster
'70 Nova
'71 Comet
'72 Dart
'72 Cougar
'67 Chevrolet Six
'68 AMX
47 ½" 48" 51" 57 ½"
'39 -48 Chevrolet
'72 Charger
'72 Chrysler '69 Dodge Van '69 Ford Van '67 Lincoln
Original Vehicles
29-39 Chrysler / DeSoto Car 60"
26-46 Chevy Truck 58-58"
Most Early Buick, Olds, Pontiac 58-61"
28-31 Ford Car / Pickup 57 ½"
32 & 33-34 Ford Car / Pickup 56 ½"
34-48 Ford Car 57-60"
49-51 Mercury 61"
64 Falcon 58"
67 Cougar 60"
64-66 Mustang 57"
67-71 Mustang 59" 54” 55”
72-73 Mustang 60"
67-69 & 60" Camaro 60"
64-67 Chevelle 60"
55-64 Chevy car 60"
65-67 Nova 58"
68-72 Nova 60" 60"
76-80 Camaro / Firebird 61 ½" 60 ½"
________________________________________
1982-92 firebird camaro flange to flange 56 5/16
1993 94 95 97 CAMARO TRANS AM 65 ½ inches
1990 Chevy van G20 62 “ flange to flange
~Jim
