4 members (Wally / Montana, FAST55, lumbersawyer, cmayna), 163 guests, and 1 robot.
Topics128,197
Posts1,057,259
Members48,466
Has anyone found a cooling fan shroud that works well with the origional 6 blade fan and stock radiator?
I found some universal ones on line. Some were for later crossflow radiators. I would like to have a full circle shroud but could make due with a partial shroud.
Was there any model that worked better than the others? I am tempted to buy two cheap kits and modfy them.
Thanks for any advice. Craig W.
1948(10/'48) Chevrolet Loadmaster 1.5 Ton, 235cid, Muncie P211X, 137" WB, Dual Wheel Rear Axle 11,000# GVWR, Chalky Blue
I like giving advice. That way I don't have to fix it.
a shroud needs to take account of the engine/water pump position relative to the rad, if you've changed the engine there's unlikely to be a pre-fab shroud available that will work with whatever you've got - see first item here for one that will fit the rad and can be finished to fit the fan position
...it looks like you also have to make your brackets for it.
Depending on your situation I'd consider getting me some sheet metal, as wide as you need, and make your own since you have to make brackets anyway.
I've see them where the sheet metal was simpy overlapped at the bottom and pop riveted...the brackets fabbed out of 3/4 inch wide strip of metal from Ace or Lowes, or a 3/4" strip of aluminum from the same places. You would/will be surprisd how nice it will look if you take your time.
That said I know some of the earlier BIG trucks has a fan shroud on them but not sure if they will fit your application? I think I even saw one advertized for the big truck somwhere.
Hope this helps in someway.
Thanks for advice. I am going to the junkyard and see if a plastic shroud off of some other vehicle could be modifed.
The boiled and repaired radiator went back in without a hitch. The new water pump fits. I even painted it red to flash up the engine:-). A new thermostat, upper and lower rad hoses, and a few other odds and ends and its finished. Now to try rebuilding the windows/doors. They need it all.
Thanks to Jim Carter Truck Parts.
