Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (KingG, baldeagle, Gdads51, Hotrod Lincoln), 44 guests, and 1 robot.
Topics128,007
Posts1,055,281
Members48,418
#691612 11/03/2010 5:31 PM
Had my 216 engine (53)rebuilt two years ago and just now started hooking everything back up. I can't remember if I took out a adapter for the water temp gauge on the block or not. I tried to install the sensor on the block but it won't go in and I got one of those reducers from classic parts but its to big for the block. Somebody get me going in the right direction.
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #691646 11/03/2010 6:51 PM
Sounds like you just need a brass fitting (bushing) of the proper size. Any hardware or FLAPS would have it. Probably 3/8 x 1/4. Just replaced one in my Farmall but it was 1/2 x 3/8.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #691649 11/03/2010 7:05 PM
I tried to get one from ACE, the size I need is 3/8 by 3/8 but that doesn't make sense to me, both the same size?
1953 5 Window
2006 Chevy Colarado
Charley #691762 11/04/2010 2:16 AM
If you are saying that the sensor is too large for the hole in the head, something is really wrong. The bulb has to go in and be immersed in fluid.
1951 1 Ton Completed
truckernix #691783 11/04/2010 2:49 AM
As truckernix stated, the hole for the water temp sensor would be on the top of the the head.
The adapter from Classic parts is for the hole on the head of a later 235/261, which is a larger diameter hole for the electrical water temp sensor.
tclederman #691809 11/04/2010 3:39 AM
If you have a stock gauge you do not need anything, the sensor should just screw in the head.
My Blog
