2 members (2-Ton, 1 invisible),
108
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | I would like to know if there is a 12v battery that will fit in the original floorboard location in my 55 1st series truck. Can't recall reading a post asking same question.( Engine is a 2nd series, so from a previous post, it came from the factory 12v). Don't care much for the Batt being under the hood. Thanks for any ideas. Kato | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that a Group-1 6v battery was standard in 1955-1st series trucks. Here is a table of battery sizes. I had no problem finding a 12v battery that fit (but, I am back to 6v now and do know what sizes of 12v batteries I used to have). | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | kato, just measure your box and take the measurements to the parts house. Should have no problem. You may want to take in consideration if you want a top or side post though. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | May be a dumb question, but oh well. I own 2 AD trucks, and neither have the rubber floormat in place. Was the floormat just laid in the floor and then lifted up when the battery needed to be charged/replaced/etc. or did you have to take flanges loose to work on it?
I am considering building a new battery tray that will accommodate a larger battery that will fit through the hole. But that is another conversation. | | | | | Joined: Nov 2009 Posts: 72 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 72 | tclederman, thanks for the battery size table chart. Always good to have options. Achipmunk, thanks for your input. I will take a look and see which battery, side or top post, makes it easier to connect/disconnect. Thanks again!
Kato | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something to keep in mind looking at that chart, its age. Looks like the last time it was updated was 14 years ago, there's several sizes listed on there that simply are no longer being made, plus many new sizes that's been added.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Maybe someone could post a link to an up-to-date chart/table?
Or, maybe someone could confirm that the 6v battery is Group-1. Then someone could take a tape measure and the Group-1 dimensions to a battery store and easily find ones that fit?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Jon, the truck came with the mat tucked under the firewall pad and layed on top of the step plate or windlace retainer. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I tried looking for an updated chartonline the other night, everything kept comming back to the list that you posted, Tim. If I can remember to look, I might be able to get an updated chart from the shop tomorrow. Need to see if we have a spare book I can "borrow"  for a few days.
