1 members (greenie-reddy), 101 guests, and 3 robots.
Topics128,090
Posts1,056,380
Members48,442
#691039 11/01/2010 7:57 PM
I
I Offline
I just got back my engine from the shop. How do I properly break this engine in ? Thanx !
The best thing to do is go back to the shop and do what ever they tell you to do,ask them what oil to use and give you a startup sheet and breakin sheet on the engine it should also give you the timming spec's oil pressure spec's,etc,etc.It's there engine for a year or how many miles.
Pete
Run it at 1800-2000 RPM for about 30 minutes to break in the cam. I agree that you should have been given a spec sheet if it's a machine shop and they built it for you. Use Shell Rotella in 10-30 weight for break in then run whatever brand/type you prefer.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
My 2 cents,
First, what type of cam is it, roller or hydraulic? It makes a difference on the break in.
Then find out what is on the camshaft, what did they use for prelube? grease or oil type. It matters because grease will still be on it, the oil types will drip off in a day or so.
Next, does it have stock valve springs or some high seat pressure springs (race type)? This matters because you need to know how much load is on the cam. The heavy valve springs can kill a cam very quick if the cam is not lubed enough. With heavy springs, cam manufacturers recommend removing the inner springs for break in to lessen the load on the cam.
Use a good quality oil, I like the Brad Penn Racing oils, you can find it on line, its loaded with all the ingredients need for break in. Also add one bottle of GM ESO oil additive from Summit racing or your local dealer. Add it no matter what oil you choose.
Pre prime the engine, rotating four turns only pausing every 90 degrees to fill all 16 lifters with oil. Keep the drill running the whole time.
Have a carburetor that runs good, ready to bolt on with fuel in it. Pre run it on another engine if needed, it must be ready to fire off asap.
Have the ignition as close as you can get it and be sure it runs and works as it should.
Have the cooling system filled with water only, water cools better then coolant and if some thing goes wrong, you are not standing in sticky coolant. Have a hose handy to cool the radiator if the fan is not keeping up. Don't let the engine get above 200 or 205, and try your best not to shut it down during break in.
Once it starts, get it to 1800 rpm right away, set the timing by ear. The first minute or two is the most important of all the break in. Have a good working oil pressure gauge where you can see it. You MUST have pressure right now or the cam will die.
Keep it running at 1800 for 15 minutes then step it up to 2000 for 5 minutes, then 2500 for the last 3 or four minutes. Slowly bring it down to a idle to set the timing and carb. Let it idle for a bit to cool down, don't shut it off blazing hot.
Keep the same break in oil in it for 500 miles or so changing the filter only if you feel the need. Be sure to add back what you take out with the filter.
NEVER EVER walk away from it, keep your eyes on the gauges and ears open for noise.
Joe
I'd pay 3 or 4 cents for that! wink
Good explanation, Joe.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
