1 members (78buckshot), 106 guests, and 3 robots.
Topics128,187
Posts1,057,212
Members48,465
Was a leaf spring rear suspension available on the '60-'63 Chevy C10 trucks? Was a leaf spring rear suspension available on the '64-'66 Chevy C10 trucks? All of the literature I have indicates the trailing arm/coil spring combination was the only rear suspension type.
I have a '66 Chevy C10 with a leaf spring rear suspension. It looks like the rear portion of the frame rails have been grafted from a donor frame and I am curious to know if it might be a factory '60-'66 rear frame/suspension assembly.
I think the C10's only came with coils, the K10 and up and the C20 and up have leaves,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
C10 and base C20 had coils, leaf springs were the heavy duty option on C20 and standard on the C30. I have heard of a possibility of the leaf option on C10, though I've never seen one. GMC used leaves on all models. Could be a possibility that either you have a GMC frame or the rear section of a GMC frame was grafted on.
Bill Burmeister
Leafs were on C30 & 4wds, coils on C20 & C10. Leafs WERE an option in the later 67-72 truck when GMC/Chevy became the same truck only diff trim. But in 64-66 if you wanted 2wd w/leafs you bought a GMC. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I have access to a 12 bolt posi out of a 75 c-10 with springs.
Can this unit be changed to fit my 65 w/coils ? Is it to wide ?
Thanks , George Hood
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
It is about 1 1/2" wider, really doesn't affect anything. You will need to cut off the leaf perches & install coil spring mounts(readily available aftermarket). I have never done it but know lots of guys who have, so it must be fairly straitforward. Up to 72 is a bolt in but they are getting harder to find. Brian
Brian,Thanks.
Any idea for the vendors that have kits ?
George Hood
Z
Z Offline
